topendtrev wrote:I think perhaps I do not explain properly. I checked oil and water then filled with fuel then started work & 20 minutes later she cut out. As the engine was running I think something must have happened to cause it to stop. As it cranks fine no bad noises wondering if injector pump failure or such like, however I can still do as you suggest and see if fuel at injectors and if not then hm will report tomorrow
thanks
Trev check your lift pump first just in case that failed; the system could also have drawn some air into it so first bleed it through and try and start her again, if she fires up okay and runs for a bit but then cuts out I would be looking a bad low pressure fuel line sucking air or at the lift pump, fix up a temporary gravity fed fuel system see if she runs on that okay.
