JCB 3D2 -75 Kingpost seals?
- Real name: David
- Has thanked: 76 times
- Been thanked: 179 times
Re: JCB 3D2 -75 Kingpost seals?
You should be able to order direct from JCB or you could try Diggerparts they also are quit often available on E-Bay, you will need your machine number if you order from JCB, Have you drained the oil and water out of the bottom of your kingpost ( you will find a drain plug on the underside of the kingpost and a refill point on the inside middle part of it). You will need an EP90 grade gear oil for this when you top it up do not fill it to the brim leave a depth of about a fingernail. Very technical.
- Real name: Richard
- Has thanked: 17 times
