Hello Guys,
I've been registered on here for a while now, using the knowledge of people on here to fix various problems with my machine.
I have taken the plate cover off on the nearside chassis hydraulic tank to clean up the hydraulic suction strainer. I somehow managed to break the gasket that seals up the plate.
Before I bodge with some "instant gasket" I was wondering if anyone knows the part number for a replacement gasket?
I have a parts manual but after searching through 900 pages I still cant seem to find the page which shows the plate/gasket/strainer.
Finally do I replace with fluid with 32 or 46 grade? It seems people use both on here.
Thanks in advance for you help.
Gary
JCB 3C MK2 Hydraulic Stainer Gasket Part Number
Topic author - Posts: 12
- Real name: Gary
Re: JCB 3C MK2 Hydraulic Stainer Gasket Part Number
Hi Gary; if it's an old cardboard gasket I'd be very tempted to make one out of some cardboard.
- Real name: Gary
Hello Jeremy,
It appears to be a cork gasket about 3mm thick so think it will need more than the cardboard trick on this occasion.
Thanks, Gary
Thanks, Gary
Wadhampark wrote:Hello Jeremy,
Thanks, Gary
Gary I'd have a quick check on Google you may pick some cork gasket up to make a replacement easier than getting the new gasket.
- Real name: Richard
- Has thanked: 17 times
- Real name: Gary
Hello Guys,
Thanks for you help.
In the end I managed to find a parts catalogue and scrolled through it until I found the part number.
For anyone else doing a service, the SUCTION STRAINER GASKET NUMBER IS: 106/82109
- Real name: Daniel taylor
have you got a link to the parts catalogue at all Gary?
any other helpful part number in it?
- Real name: David
- Has thanked: 76 times
- Been thanked: 179 times
You could always get your machine number and give JCB a call they can normally supply parts pretty quickly, or as Jeremy says make your own gasket is pretty easy. You should really use 46 grade hydraulic oil in your machine.
