Welcome to the new version of CMN!
Some help showing the new functions How-To
How-to: Browsing the forum effectively
JCB 3CX Grey Cab, Transmission Oil replacement procedure
Discuss loaders/backhoes here
Soulman
Real name: Billy Loftus
Has thanked: 4 times
Been thanked: 3 times
Flag: Ireland
Post #1 by Soulman » Fri Nov 25, 2016 7:31 pm
Hi All
Guys what is the correct procedure for draining and replacing the transmission oil and filter in a JCB 3CX Grey cab 1988 ?
E.g. does the oil have to be hot?
Any precautions that need to be taken?
Bill.
Has thanked: 404 times
Been thanked: 253 times
Re: JCB 3CX Grey Cab, Transmission Oil replacement procedure
Post #2 by essexpete » Fri Nov 25, 2016 8:05 pm
Not sure what the recommendation is but most oils are changed when warmed up. Someone may confirm but, with most torque con transmissions, you will only drain down a % of the oil as there will be quite a lot left in the converter and cooling lines. Some machines have an inspection plate in the bell housing where you can access a t/con drain point.
Has thanked: 892 times
Been thanked: 822 times
Post #3 by FOWLER MAN » Sun Nov 27, 2016 2:23 pm
essexpete wrote:Not sure what the recommendation is but most oils are changed when warmed up. Someone may confirm but, with most torque con transmissions, you will only drain down a % of the oil as there will be quite a lot left in the converter and cooling lines. Some machines have an inspection plate in the bell housing where you can access a t/con drain point.
That makes sense for draining down Pete, but I just checked the manual and it says the oil level should be checked with the machine at rest with cold oil.
Land Rover
Real name: Gordon Short
Has thanked: 3 times
Been thanked: 6 times
Post #4 by Land Rover » Sun Nov 27, 2016 4:10 pm
I haven't changed the oil on mine , just the filter .
The post from Essex Pete is correct though , ditch the casing oil and then you will need to access the torque convertor through the rubber inspection bung / cover . You can then ditch the fluid that is in the torque convertor . You need to rotate the convertor to get at the bolt or whatever the drain is .
I would be a bit careful filling it up , add about half the book quantity and give it a check . You might find the engine needs ran to get the fluid into the torque convertor .
Personally I'd just change the filter and the oil in the box itself , assuming it looks and smells ok .
What type of ATF are you going to use ?. I had ATF D2 written down as compatible .
Post #5 by essexpete » Mon Nov 28, 2016 12:38 am
Some of these transmissions oil levels are checked whilst the engine is idling or on immediately on stopping. Can someone clarify for the OP?
Soulman
Flag: Ireland
Post #6 by Soulman » Mon Nov 28, 2016 9:45 pm
Thanks for all that useful information
Where is the inspection plate to access the torque converter bung ? I had a peek under the beast yesterday. There is a little plate on the lower left side of the transmission housing which i think is the suction strainer, held by two screws.
Then underneath the transmission housing there is a large Nut which looks like a plug.
So im not sure where the heck to access the Torque Converter to drain it
any guidance on this is appreciated .. thanks
Land Rover
Post #7 by Land Rover » Tue Nov 29, 2016 4:43 pm
essexpete wrote:Some of these transmissions oil levels are checked whilst the engine is idling or on immediately on stopping. Can someone clarify for the OP?
I think the manual states that it should be checked cold with the engine stopped :)
Yeah , I was used to checking cars and other vehicles with the engine running and some other variations like being in 1st etc .
Land Rover
Post #8 by Land Rover » Tue Nov 29, 2016 4:46 pm
Soulman wrote:Thanks for all that useful information
The large rubber bung should be on the bellhousing between the engine and box .
I do not have my machine in front of me , but from what I remember it's about the size of a cigarret packet and is on the bottom face .
Have a good look at the manual , it should have clear steps and pictures , well , I think it does maybe :dizzy:
Soulman
Flag: Ireland
Post #9 by Soulman » Thu Dec 01, 2016 11:43 am
hi
So i drained the transmission oil via the suction strainer and i manually cranked the engine until i located the torque converter bung and drained that too. I changed the transmission filter and i cleaned the suction strainer.
My transmission oil was a very milky pink so i am going to check the transmission oil cooler to see if it is leaking water into the transmission oil. I think i will bypass the cooler as a test and then see if any water is leaking out from the cooler oil ports, (where the pipes to the transmission were connected to the cooler)
Does this seem like a reasonable test?
B.
Post #10 by FOWLER MAN » Thu Dec 01, 2016 2:37 pm
The milky appearance of your fluid could be down to accumulation of moisture from condensation, particularly if it hasn't been changed for a long time.
Condensation will produce water every time a hot transmission cools.
Return to “Loaders/Backhoes”
