1988 JCB 3CX 4WD Grey Cab - Boom Ram Leaking
Discuss loaders/backhoes here
Soulman
Real name: Billy Loftus
Has thanked: 19 times
Been thanked: 25 times
Flag: Ireland
Post #1 by Soulman » Mon Nov 07, 2016 2:02 pm
Hi Guys,
I have a 1988 JCB 3CX 4WD Grey Cab and the boom ram has a bad leak so seals need to be replaced.
Anyone got any advice/experiences of dealing with this type of repair, and how best to approach it?
How much does it cost typically to get the RAM seals replaced? (i already have the new boom Ram seal kit) .. I plan to remove/refit the ram on the JCB myself, to cut down on labour costs, but was considering dropping the RAM to a shop to get seals done.
Bill.
Has thanked: 853 times
Been thanked: 684 times
Re: 1988 JCB 3CX 4WD Grey Cab - Boom Ram Leaking
Post #2 by essexpete » Tue Nov 08, 2016 1:27 am
Find a local hydraulic shop and get them to give you an idea of likely cost. Seals can be quite cheap but some hyd shops can be a tad expensive. They are heavy old things to shift on your own and sometime quite hard to pull apart and reassemble. Also without the right tool getting the end cap removed can be a bit of a PITA.
Land Rover
Real name: Gordon Short
Has thanked: 4 times
Been thanked: 13 times
Post #3 by Land Rover » Sun Nov 20, 2016 6:28 pm
I've only ever done the steering ram so far , it will be hard graft on the big ram !.
I'd be looking for a shop that'll just change the seals only , leaving the painting and such like to yourself .
Can you see what condition the rod is in or is it hidden ?. Similarly bushes and pins .
I'd have the correct end caps for the hoses and ram ready .
No doubt you've thought about all that already .
Take a deep breath and fire in ....
Soulman
Flag: Ireland
Post #4 by Soulman » Sun Nov 20, 2016 11:46 pm
A mate helped me get the boom ram out using his mini digger which was great. We let the dipper arm out to one side and as flat as we could, then removed the rod end pin of the boom ram, started the engine and retracted the rod. Then we turned off the engine, let the pressure off by moving the levers and then marked and removed the pipes. then we removed the cylinder end pin in the boom ram and lifted out the ram using the mini digger which was easy. I dropped it to a shop and they have sealed replaced now. The bushing in the cylinder end was completely gone, but the rod end was fine. The hole also was gone oval so i will have to get it milled and pressed with a new bushing. New pin is probably required too but it will be a good job when its all done, hopefully.
Land Rover
Post #5 by Land Rover » Tue Nov 22, 2016 8:41 am
Thanks for that Bill .
I had a notion to start doing the bushes on the back arm , but there are a few other jobs to come first .....
Soulman
Flag: Ireland
Post #6 by Soulman » Mon Nov 28, 2016 2:04 pm
Well I have it all back together again. Definitely not a job to attempt without a machine to lift the Boom ram. Its a heavy beast. The workshop did a really good job on the cylinder end and put in a new insert and new bushing and it has left the machine super tight. Plenty of grease from here on in is all its needs :)
JoeO'S
Real name: Joe O'Sullivan
Flag: Ireland
Post #7 by JoeO'S » Fri Oct 05, 2018 2:28 am
I realize this is an old post but any advice would be great.
Where in Ireland did you get the ram cylinder end hole milled and re-bushed?
I have the same problem with my old 3CX and am wondering who could do this kind of engineering.
Joe
tomballs
Real name: tom
Been thanked: 3 times
Flag: Ireland
Post #8 by tomballs » Sun Jun 02, 2019 10:40 am
Try Paddy Denby ferns Wexford https://pdenbyengineering.ie/
Soulman
Flag: Ireland
Post #9 by Soulman » Fri Feb 19, 2021 2:07 pm
hi,
Stafford Engineering Group in Ballymount Industrial est in Dublin did it for me.
Return to “Loaders/Backhoes”
