FOWLER MAN wrote:FOWLER MAN wrote:Hi,
Is yours a rotary or in line pump ?? I can't remember now.
If it is the rotary pump I don't think it can be a blockage of the nylon filter in the pump inlet as Agrimax says.
If so you would not have fuel at the pump bleed screws.
You will need to remove the fuel feed pipe from the pump and screw out the fitting to which it was attached, (15/16 AF spanner size), to access the filter.
I think possibly it's a problem in the pump itself.
More info. please.
Hi, A few more thoughts on this one.
Have you bled both bleed screws on the pump
The bleeder on the pump body should bleed easily from the lift pump. But the other one near the top, (I think yours is facing the engine block), can be more of a problem. You sometimes have to spin the engine to bleed this effectively.
The other point is that unlike with the inline pumps CAV recommended that all four injector pipes be opened and the engine spun till all were spurting fuel before attempting to start the engine.
As a Diesel and plant engineer I worked with these rotary pumps since they first appeared in the late 1950s till I retired age 70 some six years ago so I know they can be a pig to bleed.
In the previous post I said your problem wouldn't be the nylon filter at the pump inlet as you would have had no fuel flow at the pump bleed screws.
As a matter of interest when that filter blocks the injector pump continues to attempt to draw fuel through it. This creates a vacuum in the pump and the engine,( starved of fuel), cuts out but it is not air-locked.
If it is left alone the vacuum will release itself by continuing to pull fuel slowly through the blocked filter. The pump is then full and the engine will usually start again and run briefly till the whole cycle starts over.
The only time I ever had a pump just stop like yours with no obvious cause was on a Perkins engined Priestman excavator.
I had no facilities on site so I took the pump to a near-by fuel injection shop.
Under the top cover of the pump are springs and linkages, in this case the "link hook" a rod with spring which links the governor arm to the metering valve had come adrift, they popped it back on and didn't even charge me.
I wouldn't go delving in there if I were you as it is all very carefully set up, a Vernier calliper is used to set the "link hook" length.
If you have to take the pump off it's easy enough just undo the pipes and the three nuts holding the pump and draw it out. The quill shaft which drives it has a master spline so you cant get it wrong when putting it back on.
Thanks Fred for this,
You have given me a plenty to try and No I have only tried to bleed it from the one Bleed screw on the front so maybe this could be the problem.
I have to go away for a couple of days working so when i get back I will try every this above and also give the side of the Injector pump a couple of Taps just in case it's that.
Cheers guys for all your Help and I will let you know how I get on
