I have a problem with my JCB 3c mk2 I think it might be the injector pump, what's happening is it will not start again after it's been running. I think once the stop has been pulled there is something in the injector pump sticking, because when you go to start it again it will not fire, no smoke coming out of pipe. Has anyone got any ideas.
Jcb
- Real name: Rob
- Has thanked: 195 times
- Been thanked: 281 times
Re: Jcb
A quick test would be to stall it instead of pulling the stop. If it restarts ok then that points to the stop lever as you suggest.
Another thought would be to try pushing the excess fuel button (if it has one) see if that has any effect.
- Has thanked: 7 times
- Been thanked: 43 times
Re: Jcb
Which injector pump have you? Rotary or inline?
William
JCB Hydra Digger Loadall 65
JCB 3DIII Powertrain
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
