Dave-OLW wrote:Hi,
I managed to undo the crankshaft nut with the 1" Drive socket and bar, plus a 8' scaffold pole, had to bolt down engine to workshop floor to stop it turning over.
It appears only the number 2 rod journal is damage from loss of oil, the rest look ok, can you just regrind one or do they all have to be done?
David
David its common practice to regrind all of the crankpins; the main bearing journals may get away with a polish but they may also require a regrind, if an engine fails on only one crankpin then the causes could be; that the engine was run with a low oil level, that debris from worn bearings blocked the oil feed to the crankpin or that particular crankpin big end was badly worn.
