JCB 3c MK3 new addition
davidbrown80
Real name: Roland
Has thanked: 7 times
Been thanked: 6 times
Re: JCB 3c MK3 new addition
Post #21 by davidbrown80 » Sun May 08, 2016 10:12 am
i just put a replacment crankshaft with new bigends and mains regound the valves etc had it fired up yesterday and sound find with good oil presure
davidbrown80
Real name: Roland
Post #22 by davidbrown80 » Sun May 22, 2016 9:24 am
well as i thought the cab need a full rebuild so i have now taken it off so ill remove and rebuild the dash and electrics check the brakes while i have the floor plates up repaint the gearbox /axle repair the door side wing top etc and does anyone know where i can get some cab glass as thers not a good pane in it. i will take some more pics soon .
Mrsmackpaul
Real name: Paul Griffiths
Has thanked: 384 times
Been thanked: 256 times
Post #23 by Mrsmackpaul » Sun May 22, 2016 11:22 am
Sounds like your getting stuck right into it
the cab glass would all be flat glass I would have thought if so any windscreen place should be able to cut the bits out you need for not much money
davidbrown80
Real name: Roland
Post #24 by davidbrown80 » Sat Jun 25, 2016 10:41 am
just a couple of pics of progress slow but sure
rear wheels now removed and some time cleaning and painting. looks much better! the pressed metal 3c badges are a bit worse for rot will have to try to replace or repair.
Has thanked: 1873 times
Been thanked: 1691 times
Post #25 by Jeremy Rowland » Sat Jun 25, 2016 8:03 pm
Looking good Roland :claphands: keep up the good work.
davidbrown80
Real name: Roland
Post #26 by davidbrown80 » Fri Dec 16, 2016 11:24 am
well its been a while since i posted any pics but been quite busy all the same so ive put some new pics on showingthe replacement front axle and the work on rebuilding the cab which is finished now with the paint work done rooflining fitted and the (another genuine JCB sticker ) (made by my son ) attached. rebilt dash back in and all electrics in and working , back hoe as had a quick coat of paint bonnet is now back on just leaving the front loader to do .
Post #27 by Jeremy Rowland » Fri Dec 16, 2016 11:43 am
Looking good Roland :thumbup: but I must say unless its just the photograph your track rod looks slightly bent to me?
davidbrown80
Real name: Roland
Post #28 by davidbrown80 » Fri Dec 16, 2016 11:49 am
yes theres a slight bend in the rod but i dont think it will be a problem its been very difficult to find any replacment track rod ends but i managed to get this complete tracrod with the ends allready on and they seem pretty good . i do think the photo does make it look more bent than it is though
davidbrown80
Real name: Roland
Post #29 by davidbrown80 » Fri Dec 16, 2016 11:57 am
just found some more photos of work so far
Mrsmackpaul
Post #30 by Mrsmackpaul » Fri Dec 16, 2016 8:48 pm
Roland you do some pretty impressive work there looks as good if not better than when new
