1984 jcb 3cx gearbox/transmission oil
Topic author - Posts: 18
- Real name: Peter
- Has thanked: 3 times
Re: 1984 jcb 3cx gearbox/transmission oil
Thanks so much for the help. I have managed to get some dynatrans ac10w so will be using that. There is ATF in the shuttle at the moment so I will need to drain that out and replace with the dynatrans. I understand from reading other posts that not all the atf will drain out so I guess some will mix with the dynatrans. Do you think this is anything to worry about?
- Been thanked: 684 times
petervickery wrote:Thanks for all the replies. Pete says a 10w transmission oil and Phil and David say 10w engine oil. Is this the same thing? Also I have googled dynatrans and find a dynatrans MPV and also a dynatrans AC. Which one would it be?
IIRR the JCB drum 10w used to say transmission and light engine oil.
hello Guys
i have recently purchased the same year machine would anyone have a manual for this type of jcb? serial no is 3cx-4 301604/p
thanks in advance
thanks in advance
- Real name: Wayne
Hi Pete, my machine is 309133 and manufactured date is 29/09/1984.
