advice please my 3 cx if given a bit of power to get out of heavy mud for a short time gives a small burning smell once clear of nearly stuck mud all ok PROBLEM 2 rear arm when lifting full bucket of heavy clay and slew left or right will creak a bit when only half full no noise any advice please on my problems
JimL
3cx 1984 BURNING SMELL
Topic author - Posts: 37
- Real name: Jim Leslie
1984 3cx sitemaster/leyland 270
R.E.M.E. motto you break it we fix it tomorrow
Re: 3cx 1984 BURNING SMELL
No heads up guys pleaseThe Jannie wrote:advice please my 3 cx if given a bit of power to get out of heavy mud for a short time gives a small burning smell once clear of nearly stuck mud all ok PROBLEM 2 rear arm when lifting full bucket of heavy clay and slew left or right will creak a bit when only half full no noise any advice please on my problems
JimL
- Has thanked: 849 times
- Been thanked: 680 times
Creaking wear and tear on an old machine like my knees. It could be in the slew mechanism or even the whole king post twisting on the sliding rails.
Burning smell? Is the engine and ancillaries fairly clean and oil free?
- Real name: Nick
- Has thanked: 41 times
- Been thanked: 10 times
Give everything a good greasing, may stop creaking, otherwise as said, old machines will creak and groan, especially if your working her hard! Ditto if she's working hard to power through heavy mud, then the engine and transmission are working a lot harder than normal and will get hotter as a result. Unless you can actually see and identify where the smoke/smell is coming from then it's difficult to advise further. Seen 3C's overheat when being worked hard, one had a man on the front controls and another on the back, trying to get it out of a sticky patch!
Thanks guys will gunk engine etc and try and see anything burning smell only NO SMOKEHugh Jaleak wrote:Give everything a good greasing, may stop creaking, otherwise as said, old machines will creak and groan, especially if your working her hard! Ditto if she's working hard to power through heavy mud, then the engine and transmission are working a lot harder than normal and will get hotter as a result. Unless you can actually see and identify where the smoke/smell is coming from then it's difficult to advise further. Seen 3C's overheat when being worked hard, one had a man on the front controls and another on the back, trying to get it out of a sticky patch!
Users browsing this forum: No registered users and 22 guests
