Hi there,
Does anybody know what size the front tyres should be on my jcb 3cmk111 (mine are perished and I cannot read what it says on them)
Will 3cx tyres fit?
Thanks Tom
Jcb tyre sizes
- Been thanked: 192 times
Re: Jcb tyre sizes
The standard 3 rib front tyres are 9.00x16 on a 3C. Likewise on a 2wd 3CX. Rims are interchangable. However,some fitted wider,lugged tyres to spread the load better,which were 12.00x18 as usually found on a 3D. It should still be obvious whether yours are 3 rib or lugged(as in a 4wd tyre).
Topic author - Posts: 27
- Real name: Tom
- Been thanked: 4 times
Re: Jcb tyre sizes
Mine must not be standard then, they look like old trailer tyres
What would you recomend the 3 ribs or lugged?
I might aswell replace them both as the other one doesn't look to good either.
Cheers Tom
Cheers Tom
Re: Jcb tyre sizes
The 3 ribs will be cheaper. You may have to measure your rims to determine what size they are. Not across the overall diameter but across the next bump in the rim.ie where the beading edge is seated.Any pictures?
Users browsing this forum: No registered users and 16 guests
