JCB 3D111 interchangeable with other JCB
Topic author - Posts: 8
- Real name: john
Re: JCB 3D111 interchangeable with other JCB
Hi Again... I am hoping that I get an answer to this right away, a fellow bought that back hoe I was talking about and has offered us to buy the transmission etc... I really need to know if it will fit.. this is the backhoe we were looking at awhile with all the info in the first post... I know that some wrote it won't and some wrote it would,,,, we don't mind if we are missing a low gear or high gear we just need it to run,,..lol... thanks in advance!
- Real name: phil wheelton
- Been thanked: 29 times
your gearbox and the other m/c should have the same gearbox casing it's the gears in the box that need some work your gearbox with the /3 is a brockhouse torque converter unit with a 4 speed box on the back the other gearbox is a 5x2 box so it has high & low in the front of the box and 1st/ reverse which your box don't have,you can take the gears that are not needed out and fit the box to your m/c it's a big job but can be done.you just need an old jcb or tractor fitter from the 70s
- Real name: john
Good Day everyone.. I am back with more help needed.. we have just found another backhoe.. I have the serial numbers for both and would like to know if the other transmission will fit ours.
Ours==== 3dIII serial 13579/3, engine 498nt 200269120, tractor SKI/004140
the other one.. the gentleman said that this is what he could read, we are 22 hours away from this machine so I would like to make sure it will fit before we get there!
3DIII serial 12656073 (wondering if that is /3), engine 51145, tractor 3648227849
thanks in advance and have a great day
- Real name: john
I found another machine Good Day everyone.. I am back with more help needed.. we have just found another backhoe.. I have the serial numbers for both and would like to know if the other transmission will fit ours.
Masseyjohn wrote:Hello.. I have a JCB and the rear end and transmission need replacing I have found another JCB but not the same model, here are the numbers mine:
serial # 3D111 135279/3
tractor # sk 1/004140
the other one:
3D 54098
tractor# 384B134253
Engine #34867
65B/14134253
So now I hope someone can help me..thank you
- Real name: john
Hello to everyone and I would like to thank Mark Rive for all his help.. we did buy the rear end from the machine we chatted about and we now have a working JCB again... thank you for all your help A year and a half later but she is working now!
