Hi, I've had a trawl through but can't find an idiots guide to replace the seals on a 3c 2 back actor. I can see 2 rams, it's one furthest from the bucket is leaking and I need to sort it. Is there a certain way I have to set the machine up first before I start to knock off the cap? Any advice most welcome. I reckon I can get seal kits from JCB!
Rgds, Spud
3c 2 back acter seal replacement
- Real name: phil wheelton
- Been thanked: 29 times
Re: 3c 2 back acter seal replacement
All the rams on a 3C 11 need a "C" spanner to undo the end cap they come in a couple of size's as pete says the gland and wiper seals were split to save you from striping the ram down just make sure there is no damage to the rod before you reseal it.
- Been thanked: 685 times
I know this is not the proper way but if there is a light score or pit that has a raised edge then you can carefully buff it down with an oil stone. If It is really bad obviously it will leak. It can be surprising how long it might last, particularly if not in heavy use.
Topic author - Posts: 59
- Real name: steve
......... thanks all, managed to get some insruction froma local guy but I do need the seal kits for both boom and dipper. Tried diggerparts but they have stopped supplying them. Will try local JCB dealer tomorrow. Cheers
