on the new to me 3cx , it has a check valve fitted to the lift ram
i am finding it to be a pain in the rear , it does not seem to open quick enough and lags behind, which leaves me over compensating for the lack of movement ,and then it drops to quickly i do not have any problems grading etc
anyone else find them a pain , mines a manual control not servo
check valves
Re: check valves
I have herd about this many times, they need to bypass the check valve for normal digging operations.. I had a check valve fitted on my 4/1 clam circuit to stop the front blade opening, it made it pretty much impossible to use mainly because it was so slow!! (Jcb eventually performed the propper fix in the end!)
Topic author - Posts: 774
- Real name: graham
- Has thanked: 97 times
- Been thanked: 74 times
Re: check valves
i can see the spanners coming out it does seem to be a common complaint with the machines fitted with it
cheers graham
cheers graham
- Real name: Steve
- Has thanked: 1248 times
- Been thanked: 1834 times
Re: check valves
jcb4cx wrote:i can see the spanners coming out it does seem to be a common complaint with the machines fitted with it
cheers graham
Should have bought a CASE
- Real name: graham
Re: check valves
Neversweat wrote:jcb4cx wrote:i can see the spanners coming out it does seem to be a common complaint with the machines fitted with it
cheers graham
wash your mouth with soap i would rather a 3c
or should have tried a volvo
Re: check valves
I've been looking at volvo lately, but they are just far too slow on the road, just like everyone else really..
- Real name: graham
Re: check valves
DaveJCB wrote:I've been looking at volvo lately, but they are just far too slow on the road, just like everyone else really..
i have heard that too ,and i can do a fair amount of roadwork a day too
also the weight may be an issue on footpaths etc
still would love a go on one with sticks
cheers graham
