3D Rev counter one of many things to fix.
Topic author - Posts: 26
- Real name: Tim Arnold
- Been thanked: 2 times
Ok sketches sent to fabricators to get the rust in the cab fixed, while i am waiting I want to get some other bits working. I have removed the drive cable from the back and it does not turn nor can it be turned. I have traced the other end and guess the rad will need to come out for access. now from experience can anyone tell me if its the cable or the drive gear thats most likely to have failed, then I need part numbers and were to source from.
Tim Arnold
http://www.parklandsholidays.co.uk
JCB 3D3, Benford 1ton Dumper, Benford Pedestrian Roller.
Re: 3D Rev counter one of many things to fix.
Last week I take mine out. It's a cable drive and it was seized. the other end of the cable is near the fuel pump, on the front of the engine under the cooling fan. The cable it self mesure 91'' in my 3D mk3 and i don't find any place to buy it here in Canada!, i might look on the net!
- Real name: Mark Rive
- Has thanked: 33 times
- Been thanked: 26 times
You can remove the tacho drive unit from the timing cover without removing the rad for sure. The drive does seize. The part number if you need one is 02/300113 for drive. Gasket 813/00197. I'll look up the cable later, its not easy to find on the parts list because its not listed with the drive or the instrument cluster Cheers Mark
Ah, there it is. under "Electrics-engine-xx" Cable part no= 109/77400
Mark
Thanks for that, gonna have to get busy with the degreaser as everthing enginewise is black and furry. Then I will be able to see whats what.
Now if anyone is scrapping something similar, the front grille has taked a bash on the RH side which has been badly straigtened, by the time I have cut out the damage it would be easier to cut the whole lot off and replace it. If you can help let me know your price and where you are.
Tim Arnold
- Real name: Nick
- Has thanked: 41 times
- Been thanked: 10 times
Tim, it might be worth giving these guys a shout see if they've anything that'll suit. http://www.vicaryplant.co.uk/
