I have just received a slightly unusual wheel loader. It is Japanese and is called the Kobelco LK400.
I have not seen this model before. Most things seem to work on it. But the drive belts in the engine slip and need to be replaced. Anyone know where I can buy these belts?
Kobelko LK400 how to find parts
- Has thanked: 1882 times
- Been thanked: 1695 times
Re: Kobelko LK400 how to find parts
Hi Andy nice loader, I would take the old belts off and measure them and have a loook see if there is a local belts, bearings, drives supplier, even an internet one, cheaper than OEM.
- Real name: ian
- Has thanked: 126 times
- Been thanked: 116 times
If you are lucky, somewhere along the top surface of the belts will be the size moulded into the rubber.
Often the size is printed on and becomes unreadable with age.
Either way, they will be an off-the-shelf part available (as above) from and decent belt stockist.
If you measure the width at the top, you'll be able to determine if it's an A or B section belt:
A = 13mm
B = 17mm
Given the small pulley on the alternator, one of the "cog" style (pseudo toothed) belt will improve the life span due to improved flexibility.
A = 13mm
B = 17mm
Users browsing this forum: Google [Bot] and 7 guests
