Looking at your pics, does the bottom pin have a tapped thread for the bolt?
If so, that was changed/improved on later models where the hole is plain and passes through the pin (and cylinder eye).
The bolt passes right through with a nut on the far side.
This has the distinct advantage of not seizing in the pin. Worst case, you can blow the head off with an oxy and drive the bolt through with a punch.
JCB 3CX 1988 Stabiliser Jack Hydraulic Ram leaking
Topic author - Posts: 70
- Real name: Billy Loftus
- Has thanked: 19 times
- Been thanked: 25 times
Re: JCB 3CX 1988 Stabiliser Hydraulic Ram leaking
the pin is not tapped but the Eye of the ram end is threaded. so the Bold threads in through the eye of the ram and into the retaining pin to prevent the pin slipping out of place.
Here are some picts of how i removed the ram end cap. I mounted the cylinder onto the machine frame using the top pin and then using a Large stencil plus a pipe, i was able to crank open the end cap. i used a ladder to support the cylinder in a horizontal position once i got a turn on the end cap, i connected the hydraulic pipes and i then extended out the ram. Then continued to removed the end cap. Have a drum and funnel ready to collect the Hydraulic oil and slowly I pulled out the piston rod. A lot of Hydraulic oil comes from the cylinder, so be ready!! Note on mine, there was no grub pin in the piston end, i removed the old seals to check for this and then i removed the piston bolt to remove the piston end.
- Has thanked: 1888 times
- Been thanked: 1704 times
Re: JCB 3CX 1988 Stabiliser Jack Hydraulic Ram leaking
Nice one always good when the job goes well.
So I received the seal kit yesterday. The kit i ordered was - https://www.kellymachinespares.ie/produ ... 991-00015/. All the seals in the kit were correct except for the 0 ring that is inside the piston bolt. The 0 ring seal in the kit was much thinner and smaller than mine. I got a suitable 0 ring from my 0 ring kit box and fitted it and it worked fine. With all new seals fitted, I hooked up the hydraulic pipes to give the ram a good test a few times before putting the cylinder back onto the machine. No sign of any leaks so i went ahead and refitted the stabiliser ram to the machine. It all went really well.
These are old seals apart from the 0 ring that fits inside the piston bolt.
Seal Kit No. 991-00015. These are new seals (the small 0 ring in this kit was incorrect size for my Ram)
All back together again.
Users browsing this forum: No registered users and 22 guests
