Hello,
Can anyone provide me with the part number (or a diagram) for the washers that fit on the cylinder head's oil feed banjo bolt please?
Mine keeps on dripping and it appears there are two thick washers. Each washer has a very perished rubber insert.
Firstly should there be any copper washers as mine hasn;t got any?
And secondly, the order of fitment is:
Banjo Bolt Head - 2 thick washers - Oil Pipe fitting - cylinder head. Is this correct, as I thought there should be a need for a washer between the oil pipe fitting and the cylinder head?
Thanks,
Part Number request - Washers for oil Banjo bolt
Re: Part Number request - Washers for oil Banjo bolt
Liam these sound like common Doughty washers (don't know if its spelt that way?) they should be easy enough to pick up from an engineers merchant or hydraulic hose supplier, should be cheap enough.
- Real name: R
- Been thanked: 191 times
Dowty washers. Your fitting seqence is wrong! Should be a washer at each side of the banjo,not both on one side. Should be copper washers instead although dowtys will work.
https://www.tractorspareparts.co.uk/amk ... -1840.html
https://www.tractorspareparts.co.uk/amk ... -1841.html
A large and small on each banjo bolt. Measure your banjo bolt to be sure of sizes.
Topic author - Posts: 113
- Real name: Liam
- Been thanked: 4 times
Thanks chaps. Learn something new every day!
I think I understand why the dowty washers have been used in such a manner - using 2 together ensures the banjo is inline with the holes in the bolt. See below, which I assume now is incorrect?
Banjo bolt:
with one dowty washer:
with two dowty washers:
Banjo bolt:
