Leyland 498 Rebuild - a few questions
Woody3
Real name: Liam
Has thanked: 6 times
Been thanked: 3 times
Re: Leyland 498 Rebuild - a few questions
Post #11 by Woody3 » Wed May 30, 2018 11:48 am
Cheers - I'll give them a bell. Thank you!
Woody3
Real name: Liam
Post #12 by Woody3 » Mon Jun 11, 2018 12:25 am
Ended up managing to source a pump driveshaft locally fairly cheaply, however, for the life of me, I can't get the pump side of the driveshaft off of the pump. I've removed the small grub screw, I've soaked it in diesel for days, I've hit it, I've even had a ratchet strap on it to try and pull it off and it just won't budge! Any ideas?
If I can't remove it, I'm going to have to try and fit a UJ joint in situ (not going to be fun!). Does anyone have the size of UJ required? I know the width of the cup is 27mm, but I'm getting various overall lengths ranging from 78.5mm up to 81.5mm as I'm struggling to measure the one insitu.
Many Thanks!
Has thanked: 1119 times
Been thanked: 922 times
Post #13 by Jeremy Rowland » Mon Jun 11, 2018 7:28 am
Woody3 wrote:Ended up managing to source a pump driveshaft locally fairly cheaply, however, for the life of me, I can't get the pump side of the driveshaft off of the pump. I've removed the small grub screw, I've soaked it in diesel for days, I've hit it, I've even had a ratchet strap on it to try and pull it off and it just won't budge! Any ideas?
Many Thanks!
can you please show us a picture of it so perhaps we can see what is held on where and how? It does sometimes help to see the bits and pieces thanks; I would imagine that the part you are talking about is held on with a taper and a keyway but I may me wrong.
Woody3
Real name: Liam
Post #14 by Woody3 » Mon Jun 11, 2018 5:52 pm
Thanks Jeremy - yes, I believe you are correct with regards to the key/taper.
This is a photo of what I'm battling against. The d link is there as I used this for the ratchet strap.
I'm hoping this will work as I'm posting it from my phone!
Woody3
Real name: Liam
Post #15 by Woody3 » Mon Jun 11, 2018 5:58 pm
Also worth mentioning, that I put a bolt in the hole in the centre, to push against the pumps shaft internally. this didn't work and sheared the bolt :doh: . I'm having an absolute mare with it at the moment, I can tell you that! :lol:
agrimax
Real name: R
Has thanked: 5 times
Been thanked: 59 times
Post #16 by agrimax » Mon Jun 11, 2018 7:44 pm
The uj is 82mmx27mm. You need to make up a puller. Piece of inch round bar through the yoke holes. Drill a hole in the middle of it's length to line up with the pump shaft. Either weld a nut over the hole or tap the hole to receive a threaded bar or long threaded bolt which can then be wound in against the end of the pump shaft and pull the yoke off. IYKWIM!
Woody3
Real name: Liam
Post #17 by Woody3 » Thu Jul 12, 2018 5:25 pm
All sorted and back together again now.
Ended up installing a new UJ insitu as no matter what we tried, we couldn't get it off. A "fun" couple of hours were had, hanging upside down in the engine bay ensuring the bearings were all in place :lol: . Just for future reference, the UJ is the same size as used on early Land Rover Series 3 and can be had for around £4.50.
Anyway, she's running now, a bit smokey when the throttle is blipped, but I'm hoping once it's been run in it will settle down. Thank you to all the chaps who have input. Without you, the digger would still be parked up.
:thumbup:
