got to the bottom of my hydraulic problem onmy jcb 3cx as the pump seized only problem is there is no plate on the pump to say what it is even after I removed it and cleaned it
removal was made easy as the key had sheared and let the shaft knock a hole in the radiator and flatternd it out along the bottom so i cannot just solder it
the machines serial number is 3cx 328997/p/s
i have tried to upload a picture from my gallery but i think it keeps loading them onto the gallery not the port at
images/userpix/64641_1J07DAIGMI51G1521106760.jpg
any help on the part number or where to buy a decent but not too expensive replacement gladly received
jcb 3cx hydraulic pump identification
Topic author - Posts: 10
- Real name: mike
- Has thanked: 3 times
- Been thanked: 191 times
Re: jcb 3cx hydraulic pump identification
Looks like a 1986/87 black cab you have.(white cab model ended in 84) Would guess you have a David Brown tandem pump but can't be sure. Vicary Plant would be worth a call for new or used parts.They specialise in JCB. Or White House Products. You'll get their contacts via Google.
Users browsing this forum: bigboss006 and 42 guests
