have jcb 3cx greycab, hydraulic tank is at front both sides of radiator, is there a drain plug for the hydraulic system, if so where is it? have water in the hydraulic system
thank you
Geoff
Jcb 3cx hydraulics
Topic author - Posts: 1
- Real name: geoff
- Real name: R
- Been thanked: 191 times
Re: Jcb 3cx hydraulics
The white cab has a drain plug under the tank.Would expect the grey cab to be the same. You'll likely be changing/washing the suction filters for the hydraulics and steering too,which are behind the right side round plate on the tank,just in front of the front wheel.
- Real name: Gordon Short
- Has thanked: 4 times
- Been thanked: 13 times
There is a plug below the tanks with a sealing washer .
It is a bit forward of the axle so you can actually catch the oil without it going everywhere .
Is the oil cooler burst ?
