Evening CMN,
We are seem to have a problem with the transmission on the family's 580G.
Basically it's lost forward drive, although it's fine in reverse so I assume it's a problem with the forward clutch pack? Are there any further tests to carry out or checks to be made or any advice as to where we go from here? It's been a very reliable machine up until now so would hate to park it up for something relatively simple.
Any ideas gratefully received
Ian
Case 580G
Topic author - Posts: 21
- Real name: Ian Greenaway
- Been thanked: 3 times
Re: Case 580G
A bit more info for you all. The shuttle seems to be a Borg Warner unit, would this be the same unit as fitted to early JCB 3cx machines?
- Has thanked: 1887 times
- Been thanked: 1701 times
Re: Case 580G
Hi Ian hopefully some knowledgeable CMN member will be able to offer you a bit of guidance.
- Real name: dylan jones
- Has thanked: 40 times
- Been thanked: 33 times
Re: Case 580G
I have just had my transmission mended in my 1986 180. Mine was the pump. Picking it up tomorrow so will tell you more then.Yours is definitely worth doing
Re: Case 580G
Hi diggerjones, what symptoms did you have with your machine?
How did you get on dropping the box out?
and who did the overhaul for you?
Users browsing this forum: No registered users and 43 guests
