1984 3cx pump codes
Topic author - Posts: 18
- Real name: Peter
- Has thanked: 3 times
1984 3cx pump codes
Could anyone please help me with the fuel pump code for a 1984 jcb 3cx running perkins 4.236 with lucas CAV pump. I took the top off the pump and the spring came loose before I could note which hole it was connected to. I have reconnected middle to middle but I'm not sure if this is correct. The motor runs ok but stalls if I completely release the accelerator. Thanks in advance.
- Real name: Peter
Re: 1984 3cx pump codes
So I managed to find out that the code is 5. It was part of the model/serial number. That means that the spring should be connected from the middle hole of the throttle lever to the middle hole of the upright part of the throttle.
Users browsing this forum: Google Adsense [Bot] and 48 guests
