Hello Gerard Dewier , I have known this m.Wikes , a UK contractor who worked in Belgium . It was a father-son team . They had DW21's.
In 1965 I worked for a Dutch contractor in Gosselies , preparing the Cat area . I pushloaded their DW21's with a D8H . I don't remember these scrapers were equipped with your "electrics" . But I do know this system has existed . It was called SYNCHRO-TOUCH and was available as an option on the series G DW21 . There was a selector lever and on the transission there were solenoids that moved the shifter forks . Also the clutch was controlled by the system . In Holland was a contractor who had DW21's with this system so it was no privilege for the UK .
I try to send a picture . If you want more information I could scan the original spec sheet . The Netherlands , DAJOCAT
Caterpillar DW21
- Real name: J.Vellinga
- Been thanked: 18 times
Re: Caterpillar DW21
Users browsing this forum: No registered users and 16 guests
