The two D8's move in and make a start
Re: The two D8's move in and make a start
Absolutely Splendid photos Dave!! Those pictures bring back nostalgic memories! If not for a JCB Fastrac and modern white van in the background of some of them, they could have been taken from the bygone 60`s and 70`s. Lovely D8 examples and a total credit to the owner!!
Topic author - Posts: 107
- Real name: Dave Merrin
- Been thanked: 4 times
Thanks Dave, I have tried to tidy them up a bit,
heres one for you
heres one for you
- Real name: martyn henley
- Has thanked: 38 times
- Been thanked: 50 times
Great pics Dave ..spot on with the black an white ..
yellowiron wrote:Thanks Dave, I have tried to tidy them up a bit,
heres one for you
Ahhh, beautiful monochrome shot..........perfect!!!
Many thanks Dave.
Now the D6C and D4D have joined to make it a proper vintage
As Tesco says..............Every little helps!
Some more
- Real name: nicky lamb
- Has thanked: 7 times
- Been thanked: 43 times
Tidy D6C Dave,Is it a 47J or 83A.It looks like an 83A.Did you get the D8 running yet with the valve problem?
Hope the weather holds down there for you.
Yes Nicky, its a 47J. Its been residing at T&H plant for the past couple or three months where Dick has worked on it solid for all that time, he said it is the most abused and neglected Cat he has come across (Not by me I should add!) just had a full engine rebuild,rad core, all of one new final drive, now the torque converter is tired...so that will be next
Due to the wet weather, the 90 box is just too much of a handfull for the 22A, so tomorrow its coming off and a 435 takes its place..the topsoil is heavy clay type and is wet and tight and takes a lot of humping along.
The 128 winch has played up big time today on the 22A, the hoist side has been smoking hot and will either not pick the box up or not hold it up...I need to change it for a 29.
Heavy clay topsoil
Sorry to hear about the winch trouble.Make sure the 128 ccu has barely any oil in it.They blow seals easy if you have the correct oil level in it.It won't come to any harm with hardly any oil in it.You can almost run it dry.The drum may be warped.you can try swapping the hoist drum for the apron drum.The warped drum will be allright on the apron side.Also you would be amazed how much adjustment you can loose by having worn linkages.Try packing them out with shims or washers,then reset the winch.If that doesn't work my advice would be to scrap it .Don't spend any money on it.That type of winch is the best IF it's in deacent condition.Once it's set up it will work all season without adjustment(unless an 'expert driver' trys to adjust it to his personal taste).Stick a 29 on it if it's too hard to set it up.These type of winches aren't as good as the 128 but they are much easier to set and run.
I am sure with time and money that you could sort that 128 but you need to concentrate on shifting muck before the weather breaks for the year and not buggering about trying to sort that bas***d of a winch.Your muckshifting capacity is down 50% with that winch prob .
I have been down that road before...........
As for having to pull the 90 off the D8,don't worry as the 435 can move alot of muck in 12 hours.You can make money out of old kit by just keeping moving.A smaller box means less winch problems and less rope breaks which in turn means better productivity.Don't over fill the box either as it takes longer to fill the last couple of cube and you struggle to tip the load.Nothing slower than a 22A D8 having to stop and reverse the muck out of the box .
I guess you know all this Dave but it's some times hard to see it when you're in the thick of it all and the pressure's on.
Keep up the good work
