Page 273 of 428
Re: Classic pictures Update 28/12/2017
Posted: Fri Dec 29, 2017 11:52 pm
by FOWLER MAN
mechman wrote:Hi Fred
I looked at that but the chain looks as though it runs over the axle of the middle set of wheels which would turn them in the opposite rotation assuming its 6 wheel drive unless the top run of the chain drives the middle set some how. Can't get me head round it.
Norm
Hi Norman,
I didn't look closely enough at the pic.
You are quite right.
The drive sprocket must be behind the top of the centre wheel.
Would there have been room for a triple drive sprocket and another short chain, (which would be out of sight), to drive the centre wheel
It is a puzzle
Re: Classic pictures Update 29/12/2017
Posted: Sat Dec 30, 2017 12:30 am
by hair bear
Wow! Three years ago, almost to the day I asked about a particular type of loader which turned out to be a Bray HS4000. Lo and behould, second pic down I do believe is just such a machine, so somewhere one survives. Thanks for posting.
Posted: Sat Dec 30, 2017 12:38 am
by hair bear
FOWLER MAN wrote:mechman wrote:Hi Fred
Norm
Hi Norman,
It is a puzzle
Would there be a small idler cog each side of the center wheel just behind the tyre so the chain runs up over then has a good wrap around under the cog then up over the other idler to keep the chain in contact? The top chain could then run over a third higher idler to keep it up out of the way of the drive?
Posted: Sat Dec 30, 2017 2:21 am
by mechman
Any one able to ID the machine?
Re: Classic pictures Update 30/12/2017
Posted: Sat Dec 30, 2017 11:33 am
by Neversweat
Posted: Sat Dec 30, 2017 4:50 pm
by mechman
mechman wrote:Any one able to ID the machine?
(looking like Meccano time).
Posted: Sat Dec 30, 2017 5:05 pm
by Neversweat
Posted: Sat Dec 30, 2017 5:38 pm
by Osgood
hair bear wrote:[Would there be a small idler cog each side of the center wheel just behind the tyre so the chain runs up over then has a good wrap around under the cog then up over the other idler to keep the chain in contact? The top chain could then run over a third higher idler to keep it up out of the way of the drive?
Reckon you've nailed it
With centre axle drive probably - idlers adjustable to take up chain slack.
Posted: Sat Dec 30, 2017 8:56 pm
by hair bear
Thanks for the graphics. If you only knew how long I spent trying to describe that so it made sense!!!
Looking at the Berliet with the lowloader and 360, is this one of those situations where he drives along the trailer, takes most of the weight off the drive axle, and the whole lot goes skating down the hill?
Re: Classic pictures Update 31/12/2017
Posted: Sun Dec 31, 2017 11:40 am
by Neversweat
