Aveling Austin 99H Grader Spare Parts.
Can anyone Help with Parts for a Aveling Austin 99H Transfer Gear Box.
We need a Sliding Dog Gear for High Range !
New or Used.
Part Number EPGQ 76132A Shifter Clutch Gear.
with thanks. Melbourne Australia.
Avelin Austin Grader 99H,
Forum rules
[For sale]
[Wanted]
[Exchange]
[Swap]
[For sale]
[Wanted]
[Exchange]
[Swap]
- Real name: Dave
- Has thanked: 57 times
- Been thanked: 5 times
Re: Avelin Austin Grader 99H,
Hi Winston (brock) welcome to CMN
There is a lad with one of those who has been on some of the plant and machinery web sites/forums with the username of Grader 99H (or similar) who has one of those machines that has been seen at a few shows. (photo below of it working)
More photos of it on this site http://www.classictracksandtrucks.co.uk/.
You could try contacting him via that web sites contact link to see if he knows of spares for them.
Alternatively the owner of a lot of the machinery on that web site is Dave Weedon (his contact details are on the van shown below) - He repairs plant and collects it so may know a breaker with one.
Dave
Dave
Interested in Tractors, Plant, Heavy Haulage or Steam visit http://tractors.wikia.com/wiki/Tractor_%26_Construction_Plant_Wiki
Help document every manufacturer model build, and record every machine in preservation, clubs and events etc.
Hello To All
Avelin Austin Grader 99H :
I am looking for a hydraulic pump for the same model grader : does anyone know where to go please????
Sue
Sue
Topic author - Posts: 5
- Real name: Winston Brocklehurst
catwoman wrote:Hello To All
Sue
Hello Sue.
The Hydraulic Pump is a.... Vickers Vane Type Pump.
It is Model V.2111-C for Machine serial up to Ref # 1531,
The genuine part # EPGQ 77015A
Model V.2111-S81-10 for later Machine serial # 1532 onwards,
The genuine part # EPGQ 77015C
hope this helps,
brock.. Australia.
Thanks Brock - that is fantastic. We tried a Vickers dealer previously but they could not reference the Genuine part numbers. This will enable me to go back to them with the correct info.
Best regards
Sue
Best regards
Sue
Sue
Hello Sue,
Did you get a New Pump ?
To adjust the Belt Tension on the Hyd Pump,
The Pulley is a split type, there are Shims between the two Flanges, there were originally ( 8 ) eight shims fitted,
remove one, or two to increase the belt Tension on the drive Belt !
Fit the spare Shims to the outside of the Pulley, under the bolt heads,
Winston.
PS. Can you tell me more about the Grader, serial no, Engine type,
Do you have a Manual/Parts Book ?
Hi Winston
This Avelin Austin Grader belongs to a customer of ours.
My boss suggested to him to try removing and cleaning the screen - this has made a massive difference, maybe the new pump won't be required after all!!!!
Thanks for everyone's kind replies, all advice very welcome.
Sue
Sue
