For Sale;
Please email for further pictures. Many items i'm looking to sell. Would prefer seller to pick up, particularly so for the heavier items, but am also willing to consider localised drop off or meet (I live in Sheffield, South Yorkshire). Also willing to look at Courier delivery at cost if required. email - richardfurniss@btinternet.com. Open to sensible offers.
1) Sealey Tools Farm Jack Lift 1200mm 3000kg Capacity FJ48 - £50
Heavy-duty lever-ratchet operated jack with reversible ratchet mechanism enabling jack to be used for lifting or lowering. Versatile and lightweight unit also suitable for pulling tree stumps and tensioning fences as well as a positioning aid for heavy machinery. Fixed upper jaw, adjustable on beam, allows jack to be used as a clamp.
Heavy-duty lever-ratchet operated jack with 1200mm beam.
Reversible ratchet mechanism enables jack to be used for lifting or lowering.
Versatile, lightweight unit also suitable for pulling tree stumps and tensioning fences.
• Weight:14kg
• Maximum Jacking Load @ <300mm Lift:3000kg
• Maximum Jacking Load @ 300-500mm Lift:2250kg
• Maximum Jacking Load @ >500mm Lift:1600kg
• Minimum Height:155mm
• Maximum Height:1070mm
• Minimum Lowering Load:50kg
• Maximum Pull Load:2250kg
• Maximum Clamp Load:340kg
2) 30" Bolt Croppers, As new condition - used twice. £25
A heavy duty cutter with tubular handles and forged steel blades hardened and tempered with a matt black finish. Five point compound leverage enables easy cutting through rod, bolt and chain etc.
• Capacity up to 16mm.
3) DeWalt DC011 Radio / Charger. £75
Runs off mains and 7.2 Volt to 18 Volt NiCd/NIMH batteries
• Charges DEWALT 7.2 Volt to 18 Volt NiCd/NIMH batteries
• Digital tuner with LCD display, built-in clock, and 8 station memory presets
• Dual pivoting 28 mm flexible antenna provides more durability and better reception
• Heavy Duty AM/FM radio with auxiliary port allows user to listen to the radio or CD (when plugged into auxiliary port)
• Heavy Duty storage case allows storage for CD player and CDs
• High efficiency weather resistant speakers with dual bass ports for maximum bass and range
• The DEWALT 3-stage charging system provides maximum run-time and extends overall life of the battery
• Weather sealed charger door opens easily for fast battery changes
4) Power Craft Air Impact Wrench. Never Used. Boxed.
Comes with 10 no. metric chrome vanadium sockets 9mm to 27mm, extension bar and lubricating oil. £15.
5) Record V150B 6" Woodworking Vice.
New, boxed. £20
6) Draper BV100 100mm Bench Vice.
New. boxed and still wrapped in protective packaging. £45.
7) 'Budget' BWK4004 Power Hoist.
1kW 230V motor, lifting capacity up to 400kG.
New, unboxed - still sealed. Steel cable dia. 4mm. Length 12m. £28.
8) 2 no. 6' Aluminium Spirit Levels.
£5 each.
9) Makita PD491 (branded Dolmar) post hole borer. 8" auger, approx. 3' length. 2 stroke engine branded Tekeusi. 49cc 2 stroke motor, 2HP. One person operation. £185
• Decompression valve on head for easy starting
• Single handed throttle operation
• Dual handled frame
• Electric ignition
• Dry weight 9kg
• Fuel tank capacity 1.1 litre
• Maximum auger size 250mm
10) Performance Power 1kVA Generator, good condition, good runner. Still has tank of fuel. Frame earthing connection, 230v AC socket and 12v DC socket for car battery charging. Large fuel tank - gives around 5 to 8 hours running dependant on load. £45
11) Wacker BS52Y Vibratory (upright trench) Rammer £395
2.4HP 2 stroke engine
1.8kW power output
weight 126 lb's / 57kg
14" x 7" foot fitted.
Built new on 3 June 2005 by Specialised Plant Services, Worksop - Neuson Wacker approved technician.
12) Panther Hydraulic Power Pack Breaker £250
Supplied with hydraulic hoses, breaker and steels (wide and narrow chisel).
13) Rexon SM-16A Bench Morticer
New, unused and unboxed. c/w half inch morticing chisel bit.
2 bolts missing that hold the hand wheel to the cast iron bed.
single phase 230v 3.8a
1/2hp induction motor
2850rpm
base to chuck = 10"
weight = 30kg
13mm drill chuck
19mm chisel fitting
very handy and portable machine
4 holes in base to bolt to bench/ workmate.
List price £250. Looking for £175
14) Hilka 6" Bench Grinder 0.5HP Pro Craft
New, boxed and unused. £40
15) Makita DCS520 petrol chainsaw. Excellent condition. Regularly stripped, cleaned and maintained.
Engine: 2-stroke Cubic Capacity: 52cc Horsepower: 3.3hp (DIN) Bar Size: 45cm Semi Chisel Chain - Pitch Gauge: 3/8" 0.058" Ignition: electric
Supplied with blade guard, spare chain, steel carrying case, chainsaw oil and Jonsered chainsaw gloves.
Cost over £400 new. £245 ono.
16) Wacker VPA1740 plate compactor. 1.7 tonnes compaction force. Honda GX160 5.5HP 4 stroke engine.
starts and runs well. £450 ono
17) Cement mixer & stand230v, approx 130 litre drum
Runs well - good condition
£115 ono
18) Sealey SB951 Shot Blasting Cabinet, supplied with moisture trap, approx.10kg fine glass bead media, air hoses and 50 litre 230v air compressor.
Would cost over £300 to put together individually.
£225
19) Rexon BS10KA Bandsaw and stand.
Minimal use.
Spare blade
Bandsaw list price £490. Asking £250 ono.
20) Double extending wooden ladders
Excellent condition, no splits or shakes - stored correctly
extends to approx 7.5 - 8m total
£45
21) Britax 324-00 12v Magnetic amber beacons
Good condition - full working order
Magnet can be used at speeds up to 50mph
4 available - £15 each
22) Various builders hand tools
A number of spades, shovels, grafters, picks, mattocks, tampers, fencing tampers, fencing pins, 450mm road cones x 8 - open to offers for the lot. Email for further details
23) Screwfix Kitchen Worktop Routing / Jointing Jig / Template includes locating pegs.
As new, only used once. £45
For Sale - Various Tools & Equipment
Forum rules
[For sale]
[Wanted]
[Exchange]
[Swap]
[For sale]
[Wanted]
[Exchange]
[Swap]
- Real name: john o`shea
- Has thanked: 80 times
- Been thanked: 9 times
Re: For Sale - Various Tools & Equipment
RMFurniss wrote:For Sale;
• Weight:14kg
New, boxed. £20
£5 each.
• Electric ignition
• Dry weight 9kg
1.8kW power output
2850rpm
base to chuck = 10"
weight = 30kg
13mm drill chuck
19mm chisel fitting
£115 ono
£225
Minimal use.
Spare blade
£45
how old is the hydraulic power pack ,and how many liters per min .thanks
RMFurniss wrote:Hi,
sorry, power pack sold a few weeks ago.
thank`s Richard i only seen it today
