cat 3408 engine
Forum rules
[For sale]
[Wanted]
[Exchange]
[Swap]
[For sale]
[Wanted]
[Exchange]
[Swap]
- Real name: mervyn rowe
- Been thanked: 22 times
Re: cat 3408 engine
Should check with Neil D,he had a 621 scraper which i think he was keeping for spares which im nearly sure had a v8,worth asking the question!
Topic author - Posts: 258
- Real name: john o`shea
- Has thanked: 80 times
- Been thanked: 9 times
Re: cat 3408 engine
BIGSAM wrote:on uncle sams american circus peter (the owner) has a peterbilt with a cat V8 with a RR13speed it slow off the mark but go's like the clapers when you wind it up i driven it she is gettin old now tho the rust is startin to set in pete spent a fortune abt 8yrs ago have the engine rebuilt at cats at spalding ! any way if you get the cat lump for your KW make sure you can get the right transmission ring to fit your G/box good luck with it
Thank`s Sam.
finally got the numbers, arr no 4w7475 .sn 6791708 .must call cat`s to find out what it is set up for thanks for
your help.
- Real name: Ross
- Been thanked: 27 times
Re: cat 3408 engine
v8detroit wrote:BIGSAM wrote:on uncle sams american circus peter (the owner) has a peterbilt with a cat V8 with a RR13speed it slow off the mark but go's like the clapers when you wind it up i driven it she is gettin old now tho the rust is startin to set in pete spent a fortune abt 8yrs ago have the engine rebuilt at cats at spalding ! any way if you get the cat lump for your KW make sure you can get the right transmission ring to fit your G/box good luck with it
Thank`s Sam.
your help.
The Serial Number is wrong. the pre-fix is 67U - 0 - 1708 = 3408
Wrong Arr number with this paticular Serial.
67U01708.
Arrangement No: 6N-3488
Mfg Model & Year: 3408 1978
Prod Family: ZL 3400V/C27-C32 Engines
Build Date: 03Jan1978
Ship Date: 21Sep1978
Sales Date: 14Dec1978
Selling Dlr: Q640 = Saudi Arabia
Ask the Gent to double check the serial & Arr numbers.
Re: cat 3408 engine
Ross wrote:v8detroit wrote:BIGSAM wrote:on uncle sams american circus peter (the owner) has a peterbilt with a cat V8 with a RR13speed it slow off the mark but go's like the clapers when you wind it up i driven it she is gettin old now tho the rust is startin to set in pete spent a fortune abt 8yrs ago have the engine rebuilt at cats at spalding ! any way if you get the cat lump for your KW make sure you can get the right transmission ring to fit your G/box good luck with it
Thank`s Sam.
your help.
67U01708.
thank`s Ross like you said it is wrong should have known my 3406A has a 92U number.
- Real name: Ross
Re: cat 3408 engine
Pretty Old skool.
This is the only Manifold for this Serial / Arr Number.
4N - 2154 Manifold Group
4N - 1675 Manifold front x2
4N - 1676 Manifold Rear x2
7N - 8175 Gasket x8
2N - 2766 Locknut x16
5M - 2894 Washer x16
2S - 3770 Spacer x16
The QTY's are for both banks. the GP number will deliver everything above in the QTY's stated.
7N - 8175 Gasket x8
