Fiat 650?
Discuss tractors here
twocows
Real name: Rob
Has thanked: 2 times
Flag: New Zealand
Fiat 650?
Post #1 by twocows » Tue Jan 21, 2020 2:01 pm
I have split my, what I think is a Fiat 650 in half to replace the clutch.
Does anyone have some specs or a manual for this please?
Seems like an old or rare model.
XS650
Real name: craig
Has thanked: 156 times
Been thanked: 374 times
Re: Fiat 650?
Post #2 by XS650 » Tue Jan 21, 2020 2:27 pm
Welcome to forum .
Any pictures, thought you were talking about cars at first ! :)
Craig
twocows
Real name: Rob
Flag: New Zealand
Re: Fiat 650?
Post #3 by twocows » Wed Jan 22, 2020 6:34 am
Tractor in good working order
After it stopped moving I diagnosed the clutch was the issue so preceded to remove it. :dizzy:
twocows
Real name: Rob
Flag: New Zealand
Re: Fiat 650?
Post #4 by twocows » Wed Jan 22, 2020 6:41 am
Here is a picture of the stand I made to hold and roll the front away
hair bear
Real name: Rob
Has thanked: 195 times
Been thanked: 281 times
Re: Fiat 650?
Post #5 by hair bear » Mon Feb 17, 2020 10:09 pm
Any progress? Don't know much about Fiat tractors, is a single or dual stage arrangement? The cover appears to have LuK cast into it - I would suspect a part no. on it somewhere. LuK still list Fiat clutch parts so a email to them direct could put you in touch with a local supplier.
Good luck, Rob.
twocows
Real name: Rob
Flag: New Zealand
Re: Fiat 650?
Post #6 by twocows » Tue Feb 18, 2020 12:49 pm
It is a two stage clutch, drive plate at the flywheel.
I took the clutch and flywheel to a clutch expert, he machined the surfaces and relined the plates, he also did all the required adjustments for $580 NZD.
All I need now is to make an alignment tool to get it all back together.
hair bear
Real name: Rob
Re: Fiat 650?
Post #7 by hair bear » Tue Feb 18, 2020 6:28 pm
I remember doing a two stage on a mf35. With a bit of patience we made a mandrell out of a piece of wood turned down on a lathe. Not ideal but it worked. You have the profile of the input shafts to work with, just needs access to a lathe.
twocows
Real name: Rob
Flag: New Zealand
Re: Fiat 650?
Post #8 by twocows » Wed Feb 19, 2020 11:02 am
Thanks for the tip, wood sounds easier than the route I was thinking.
I was looking into threaded rod and heaps of big washers filed down to make the stepped shaft.
Has thanked: 1295 times
Been thanked: 1111 times
Re: Fiat 650?
Post #9 by FOWLER MAN » Thu Feb 20, 2020 7:04 pm
I used to manage to align the David Brown Livedrive dual clutches by searching out three 1/2 inch drive sockets, one with outside diameter to fit into the spigot bearing and two more to fit into the bore of each of the clutch plates then sliding them onto a length of 1/2 inch square bar.
Use a centre punch or chisel on the bar to locate the sockets and stop them sliding along. :thumbup:
Return to “Tractors”
