Does anyone know the thread size of the spark plug hole on a 1935-38 Fordson Model N Standard?
My friend needs to retap the head. He knows it's a 7/8" but not sure what type of thread - (It's not UNF as we've just tried that and it's too coarse).
Any ideas?
Cheers!
Fordson Model N Standard - Spark Plug Thread size
- Real name: Angus Shapland
- Been thanked: 72 times
Re: Fordson Model N Standard - Spark Plug Thread size
Would that not have been tapped for an 18mm plug?
I have a Fordson N in the garage and I just checked out and measured a spare plug.
It 's 22mm metric.( Not imperial 7/8 SAE or UNF.)
It's a 22 MM fine metric thread with a 1.5 mm pitch. That works back to roughly 17+ threads per inch.
There should be no trouble finding a suitable tap.
I hope this helps.
Good luck.
I hope this helps.
Good luck.
Forgive me for sticking my nose in Fred but is that a little unexpected? That is a metric thread on a pre 1945 Fordson?
Just read a post on the Yesterday's Tractors forum that says 1/2"BSP - really??
Then this on another post
I did a little research (a while back) on spark plugs for the Fordson Model E27N.
I found that the C4 & C5 Champion spark plugs are no longer made.
The C4 is now a Champion W16Y with absolutely no crossovers available.
The C5 is now a Champion W14 with three crossovers:
AC Delco numbers C75 or C77
Autolite numbers 3075 or 3076
Prestolite numbers 78-8 or 78-10
The thread used for these plugs is 7/8” – 18
Reach is 5/8”
Hex is 15/16”
Heat range is 6
Spark gap is 0.025” for all plugs.
Reach is 5/8”
Hex is 15/16”
Heat range is 6
essexpete wrote:Forgive me for sticking my nose in Fred but is that a little unexpected? That is a metric thread on a pre 1945 Fordson?
Yes I thought that was rather unusual? Perhaps a non-standard repair? Fred?
I'm sure every other thread in the Fordson is SAE, but most plugs had gone metric pre-war.
I checked my plug with a Micrometer and Thread Guage.
Here is a Fordson N plug from the Old 20 Parts List.
FOWLER MAN wrote:essexpete wrote:Forgive me for sticking my nose in Fred but is that a little unexpected? That is a metric thread on a pre 1945 Fordson?
How very interesting Fred I never realised that metric plugs were around so early; coincidently that is how I check unknown threads at work with a micrometer and a thread gauge plus a Zeus book that lists all the threads and what TPI or pitch they should be.
Users browsing this forum: No registered users and 30 guests
