Help with a B414 gas tractor
Discuss tractors here
thewalters4
Real name: Frank
Flag: United States of America
Post #1 by thewalters4 » Thu Jun 01, 2017 3:26 pm
On first post, be kind I have gotten what I believe is a 1964 B414 gas model mechanical fuel pump was removed and electric put in place. Carburetor has been rebuilt. I can get the tractor started but it seems to want to shut off after about 10-15 minutes or when put under a load such as running the bush hog. Any help would be wonderful.
Thanks,
Frank
hair bear
Real name: Rob
Has thanked: 134 times
Been thanked: 155 times
Re: Help with a B414 gas tractor
Post #2 by hair bear » Thu Jun 01, 2017 6:35 pm
Hi Frank,
Plugs, points, condenser, and coil are all good for causing a hot shutdown. If it's new to you and you don't know the history of it, then these parts including the HT leads could be viewed as suspect and for the cost of it may be worth changing them out anyway.
Please keep us informed of what you find.
Rob.
thewalters4
Real name: Frank
Post #3 by thewalters4 » Thu Jun 01, 2017 6:47 pm
I pulled and checked cleaned plugs they looked good not worn all did receive fire new rotor installed forgot about that part. So off to look at points coil and condenser then. For a free machine I am guessing not to bad off?
Frank
hair bear
Real name: Rob
Post #4 by hair bear » Thu Jun 01, 2017 7:06 pm
Hey, if it runs and drives then for the sake of a good service, free is a damn good price!
thewalters4
Real name: Frank
Post #5 by thewalters4 » Thu Jun 01, 2017 8:48 pm
What is the HT leads?
hair bear
Real name: Rob
Post #6 by hair bear » Thu Jun 01, 2017 10:40 pm
Sorry, the high tension leads are the four plug leads and the king lead which runs from the coil to the distributor.
Has thanked: 1382 times
Been thanked: 1201 times
Post #7 by Jeremy Rowland » Fri Jun 02, 2017 7:34 am
Hi Frank and welcome to CMN :wave: hope you get your machine sorted; all good advice above the only thing I would add is that back in the 80's I had trouble with a car I was running at the time, it turned out to be points and condenser even though they were new parts that had only recently been fitted, trouble is you tend to think 'well I have already changed them' but sometimes even new parts can be duff.
Mrsmackpaul
Real name: Paul Griffiths
Has thanked: 384 times
Been thanked: 253 times
Post #8 by Mrsmackpaul » Fri Jun 02, 2017 8:18 am
When it stops running does it still have fuel in the carby ???
When you crank the throttle a few times can you see or smell fuel ??
If not there may well be something floating around in the fuel tank thats getting sucked in or restricting the inlet a bit and when it goes under load a lot it struggles for fuel
Return to “Tractors”
