Massey Ferguson 185
Massey Ferguson 185
Trying to repair hydraulics. Can someone find any manuals for that? My tractor dont drop down liftarms, except when tractor off.
- Real name: Rob
- Has thanked: 195 times
- Been thanked: 281 times
Re: Massey Ferguson 185
Hi Saulie,
Make sure the DRAFT CONTROL lever is all the way at the bottom of its quadrant, loosen any finger wheels and slide any 'stops' all the way to the bottom. You should then be able to control the arms with the POSITION CONTROL lever.
If that doesn't work it would suggest the 'over valve' is stuck which from memory is a top off the axle job.
Yea, thanx. In manual there is instructions to repair hydraulicpump that is the same that in my 185. We'll see if that helps...
