International B250. 1958 model
Can anybody tell me the procedure for removing the rear axle shafts please ? Thanks for any help
- Real name: Trevor
- Has thanked: 71 times
- Been thanked: 42 times
Re: International B250. 1958 model
Hi and welcome to the forum
These two resources below should help in that area
IH B-250/B-275 tractors servicehandbook
IH B275/B414/354/364/384/424/444/2424/2444 workshop manual
- Real name: Col Gassman
Hi Trevor3 / Mark 57 Hi guys, When I click on the second listing of manuals (last line) the page comes up "File not Found". Any ideas what might be the problem as to why I cant down load the manual? I am trying to get the IH444 manual.
Eagle Creek ( Col)
Eagle Creek ( Col)
While waiting for the service manual, here's the quick overview of what is quite a major stripdown.
1) Remove the seat and then the whole hydraulic unit that it was bolted to. You'll need to drain the hydraulic oil either by removing the short coupling hose on the right side top of gearbox or remove the filler plug (top of casting behind the seat) and syphon/suck out from there. Remove all the bolts (about 12 from memory) holding the hydraulic casting to the rear end casting - one of these you will only slacken as other parts get in the way... but you can then lift off the whole hydraulic assembly. It is heavy and probably stuck tight - I used an engine crane and lifted the whole back end off the ground before it would free.
2) Support the rear end, remove the wheels and fenders. Watch out for the lower castings that hold the fenders on as they will drop (not necessarilly immediately) and can land on your foot!
3) Unbolt the gears on the end of the axles. You'll need to remove the axles before you can get these out.
4) Unbolt and remove the axles. Again, these are heavy and it helps to have someone with you or an engine hoist.
Andrew
Andrew
- Real name: Paul Griffiths
- Has thanked: 384 times
- Been thanked: 256 times
love number 2 I wonder how you learnt that LOL
