Hi All
I have got an early 5U and need to adjust the tension on the release springs on the pinion as it disengages. As soon as the diesel fires once it throws the pinion out to soon and have to hold it in on the lever. The question is how do you remove the clutch assembly.I have taken the four bolts out but it only comes out a small amount and pulls itself back in again, help..
Thanks Michael
Cat D2 Starting Engine Clutch
Topic author - Posts: 2
- Real name: michael beeney
- Real name: Angus Shapland
- Been thanked: 72 times
Re: Cat D2 Starting Engine Clutch
Google something like D2 Pony engine and you will find tons of stuff . You can register on the ACMOC site to get even more.
I have had a look and you can't take out the clutch unit without lifting the donkey engine. You can adjust the tension springs through a small access cover, which I have now done,very fiddly especially with the fuel tank and an electric starter mounted on the wing.
Michael
Michael
fordsonmajortom wrote:I have had a look and you can't take out the clutch unit without lifting the donkey engine. You can adjust the tension springs through a small access cover, which I have now done,very fiddly especially with the fuel tank and an electric starter mounted on the wing.
Michael
Thought that to be so but knew that there was a lot of good advice available on line. Of all the D2s and 4s that I have driven I've never had the luxury of an electric start donkey/pony engine!
