Hi TC,
Your right about that heavy old mainshaft, keep you fit or kill you. It was made all the more difficult with having to shimm it all up, preload bearings and all that torture.
If you think it's someting of a marvel in the dozer you should try it in a BTD 20 Drott with the loader frame on it.
I don't think I'll be doing another. I think I'd need major repairs myself if I got involved at my age.
I hope the box in that TD18 I'm doing for Barry stays OK.
BTD20 at work
- Real name: Peter Lewis
- Has thanked: 2 times
- Been thanked: 2 times
Re: BTD20 at work
Hi Fred and T C
The early BTD20s {200series} were as Fred said 124 HP, the later (201series) were the 135HP machines.if my memory is correct the only visible diference between them was the air filters, oil bath on the earlier machines and dry on the later ones.
At Savilles so many guys ended up with bad backs and pulled muscles lifting steering clutches and the gearbox shafts out of the 20s that a crane was made up useing an old hydraulic cylinder and ram rod.
This could be bolted to the top of the main frame above the crown wheel and could be swung to each side to lift the clutches and forward to take out the gearbox shafts, that made life a lot easier.
Peter
Peter
Topic author - Posts: 6393
- Real name: MARTYN WILLIAMS
- Has thanked: 296 times
- Been thanked: 359 times
Re: BTD20 at work
Picked up the reg and Dynamo for Barry's TD 18, undrstand the injection pump is nearly ready.He said the pipes are sorted.Love to see it running.
- Real name: tony coates
- Been thanked: 63 times
Re: BTD20 at work
1 company I worked for had a small fleet of BTD20's and 24's (Beavers) the early 20's did not have the oil pressure fed gearbox or the hydraulic assistance on the steering, the removing of the top plate was always the pig for me, once it was cut into 2 sections (Gearbox -Bevel case) it was a lot better, if I could I would leave the Cab in place to work on them, this was handy to use a strap over the roof to suck those heavy lumps out, the 20's always had a work recorder fixed in the Cab.
Users browsing this forum: No registered users and 40 guests
