David Brown 1290 exhaust manifold connection????
Topic author - Posts: 5
- Real name: Jack Spratt
My DB has an open half inch male connection on the lower side of the manifold. Exhaust escapes at this point thru about a 5mm hole in the fitting. I would like to know it's purpose. Is it standard? Can I block it off? Thanks for any suggestions
- Real name: Norman
- Has thanked: 2 times
- Been thanked: 15 times
Re: David Brown 1290 exhaust manifold connection????
It's main purpose is as a rainwater drain point from the manifold. I think it should have a small tap fitting in there, similar to the one on the water jacket of the block and at the bottom of the radiator.
If you keep the tractor indoors or cap the pipe with a bean can there's no reason it shouldn't be blanked off.
