David Brown Carraro Axle
Discuss tractors here
wyrmat1
Real name: robert matthews
Post #1 by wyrmat1 » Thu Jul 14, 2016 9:54 am
Any thoughts on packing hubs on the Carraro axle with Lith-Moly grease instead of using oil, i always seem to have a weep of oil out of the hubs
Has thanked: 1450 times
Been thanked: 1280 times
Re: David Brown Carraro Axle
Post #2 by Jeremy Rowland » Thu Jul 14, 2016 10:40 am
David I cannot answer that one but what I can suggest is that you check the following;
1) Make sure the axle breather is clear and not clogged up with muck.
2) Check the axle where the hub seals run is not worn, if it is you will need a sleeve fitting.
3) If sleeves are already fitted fit new ones with silicone sealant underneath as the oil can sometimes pass the seal via the sleeve.
4) Check the viscosity of the axle oil is correct and that it is not overfilled.
RichardJW~
Real name: Richard
Has thanked: 28 times
Been thanked: 44 times
Post #3 by RichardJW~ » Thu Jul 14, 2016 11:53 am
you'd be better off using 85w-140 semi-fluid grease
Mrsmackpaul
Real name: Paul Griffiths
Has thanked: 384 times
Been thanked: 254 times
Post #4 by Mrsmackpaul » Fri Jul 15, 2016 3:47 am
which part of the hub is leaking because with out knowing you could be really just stabbing in the dark and I have mo experience on Carraro front ends but have worked on other brands and they are similar
Do you know the oil is coming from the hub and not the diff center as it will leak out the hub end as well
I would change the seal sleeves and what ever else to fix it as the planetary will have needle bearings and the grease might not lube the properly
Has thanked: 629 times
Been thanked: 435 times
Post #5 by essexpete » Fri Jul 15, 2016 11:18 pm
Perhaps do like Paul suggests, fit some new seals when you have the time. The hub parts will be expensive and possibly difficult to source on an old model. I have used grease in some boxes like the crappy one on our Macconnell Flail and dung spreader but I think you might have trouble in a hub.
sergi12
Real name: sergi labo
Flag: Italy
Contact:
Post #6 by sergi12 » Sun Sep 27, 2020 2:22 pm
You can be sure of the quality of carraro axles. If there is a piece you are looking for, we can help you from this link.
https://originalparts4you.com/carraro
You can find original and affordable spare parts for your vehicles such as construction machinery spare parts, agricultural vehicles, lifting vehicles. All you have to do is find your part by searching oem no.
Return to “Tractors”
