Ford 4000 3cyl Generator / Regulator Problem Help!
Discuss tractors here
kaiserjonty
Real name: rachel ob
Has thanked: 2 times
Re: Ford 4000 3cyl Generator / Regulator Problem Help!
Post #11 by kaiserjonty » Mon Aug 31, 2020 11:26 am
Hi mate thanks for the updated info.Yes the old owner replaced the starter a few years back. I dont have the tractor with me at the moment (its about 3hrs away at a bush block) so cant do your test anytime soon unfortunately. So to be sure I am clear I need to disconnect the dynamo/gen at the regulator ? or at the dynamo/gen ? then run a small wire between the two terminals and a wire back to the +ve on the batt? sorry just trying to visualise it!
hair bear
Real name: Rob
Has thanked: 136 times
Been thanked: 164 times
Post #12 by hair bear » Mon Aug 31, 2020 11:47 am
I know the feeling, my Major isn't that far from me but still not 'outside the door' for a spare 5 minute fix!
So to clarify, take the wires off at the dynamo and use a fresh bit of wire, that way you dodge making any other faults worse.
kaiserjonty
Post #13 by kaiserjonty » Mon Aug 31, 2020 11:58 am
Gotcha! Thanks so much for your help. I will get back in touch once I try it out. I should be able to get back up to it in a week or so (Covid restrictions here in Victoria are preventing a lot of 'unessential' travel' ! ) cheers Rachel
Has thanked: 621 times
Been thanked: 428 times
Post #14 by essexpete » Mon Aug 31, 2020 11:11 pm
Good posts Rob!
hair bear
Real name: Rob
Post #15 by hair bear » Tue Sep 01, 2020 11:06 pm
You're more than welcome, I just hope I'm right! I've got to the age now where I post something, then a couple of hours later start questioning what I wrote - that's my excuse anyway.
Return to “Tractors”
