B275, 3pth not going down,
Discuss tractors here
Dan The Machinist
Real name: Dan
Has thanked: 4 times
Flag: Canada
Post #1 by Dan The Machinist » Fri Jun 21, 2019 8:06 pm
Hopefully someone can help me here.
I've got a 1962 B275 with diesel engine and basic hydraulic unit (don't know what to call it but it's the one without the big spring in the back). Last week I changed the brake seals and brake discs in it (quite a big job) and it went pretty good but now my 3pth won't go down with the control lever it goes up no problem. The lever goes down but not the 3pth. Is that normal? I just bought the tractor with a snowblower on the back and it did go down with the snowblower on but once I took it off I never noticed if it did go down with the lever. I think it did but not sure.
One thing I did notice after I had the control valve and the hydraulic unit on the bench side by side, there was a short pin (Ø3/16" x 1/2" long) at the edge of the hydraulic unit in a hole and that hole lined up with a blind hole in the control valve. It made me think that there was a spring missing but I couldn't find one anywhere. I looked everywhere. I even looked in the parts book here and can't find that part. Does anybody know anything about this?
I know that I will have to take the control vale apart since it's now leaking at the control lever pivot point, there's an o'ring there. I'm guessing that I should probably take it all apart and change all the o'rings. What do you think and is it a big job?
I hope I explained myself well.
Dan
Has thanked: 1290 times
Been thanked: 1138 times
Re: B275, 3pth not going down,
Post #2 by Jeremy Rowland » Fri Jun 21, 2019 9:04 pm
Hi Dan and welcome to the site :wave: there is a wealth of knowledge on here so hopefully someone will be able to pint you in the right direction; Fred Evans (Fowler man) is very experienced in most plant fields he may be able to offer you some guidance.
Dan The Machinist
Real name: Dan
Flag: Canada
Post #3 by Dan The Machinist » Wed Jun 26, 2019 3:39 am
Hi everyone,
I was talking with a mechanic that used to work on this tractor a long time ago and he was telling me that the pin I’m referring to is probably a locating dowel pin and the hole in the hydraulic unit is probably a blind hole also. Can anyone confirm that?
Dan
hair bear
Real name: Rob
Has thanked: 132 times
Been thanked: 145 times
Post #4 by hair bear » Wed Jun 26, 2019 10:20 pm
Hi Dan,
It's nearly 40 years since I had much to do with a 275 so memories are somewhat fuzzy, but I think there is a hand wheel under the seat to the rhs of the gearbox marked 'higher - lower'. If the links seem to stop at the same place try going up, then wind the wheel towards lower. Let the arms down and see if the place they stop has moved.
Has thanked: 528 times
Been thanked: 339 times
Post #5 by essexpete » Thu Jun 27, 2019 1:46 am
https://thefarmingforum.co.uk/index.php ... machinery/
Hope this forum does not mind. Let everyone know how you get on.
Post #6 by Jeremy Rowland » Thu Jun 27, 2019 7:42 am
essexpete wrote:https://thefarmingforum.co.uk/index.php?forums/classic-machinery/
That's fine Pete we are here to help each other out. :thumbup: and share our common interests.
Dan The Machinist
Real name: Dan
Flag: Canada
Post #7 by Dan The Machinist » Thu Jun 27, 2019 4:54 pm
hair bear wrote:Hi Dan,
Ok thanks, I'll check that out.
Dan
Dan The Machinist
Real name: Dan
Flag: Canada
Post #8 by Dan The Machinist » Tue Jul 02, 2019 2:30 am
Good evening everyone,
Well I’ve got good news.
The 3pth goes down under its own weight on this model, I had the lever down and went around back and pushed it down and it went down quite easily.
The pin I was talking about is a locating threaded dowel pin like the mechanic was telling me.
I changed the o-ring at the lever on the control valve and I realized that the last person that took it apart forgot to put the pin back in that prevents the lever from coming out. So once I changed that o-ring I slipped a 1/8” pin in the hole and put everything back together and everything works well.
Thanks everyone.
Dan
Post #9 by Jeremy Rowland » Tue Jul 02, 2019 7:47 am
Dan glad that you have got it sorted out okay :thumbup: sorry that I could not have helped you but I have no experience of these machines.
hair bear
Real name: Rob
Post #10 by hair bear » Tue Jul 02, 2019 10:02 pm
Well done, now get out there and play!
Return to “Tractors”
