Hello Jeremy
I too had a problem with the schaft alternator but I removed the engine from the chassis, too bad I did not see your topic before disassembling my engine.
It is very interesting and well documented well done for this work, my English is not perfect I use Google translate
thank you so much
Gerard
Ps: I do not understand the picture 17 with the swing gear shift with intermediate gear
Triumph Alternator Drive Shaft Replacement
Topic author - Moderator
- Has thanked: 1883 times
- Been thanked: 1696 times
Re: Triumph Alternator Drive Shaft Replacement
Gégé78 wrote:Hello Jeremy
thank you so much
Gerard
Bonjour Gerard
Photo 17 was just showing the three gears in the correct place before refitting the clutch basket; this is the second time that I have done this job as I did the same repair on the first Triumph Trident that I owned.
- Real name: Christer Fribrock
Thank you, Jeremy.
This is very, very helpful!
I just don't agree with those 3 mm each washers for the bolt and nut at the drive. It's seems like an overkill remedy, especially with the high torque of 40 Nm recommended. Drew a nut and can't find a class 12. nut with 1 mm tread in Sweden so I had to buy a whole new set.
Later on I've heard Nm drag of 25, 30, 35 so it's confusing even with Triumph Service Manual.
I hope the clutch basket nut works smoothly on at 105 Nm.
Cheers!
Cheers!
- Real name: Chris
- Been thanked: 56 times
I do really like the look of the trident and have been considering getting one for a while now . At least I know what to look for when viewing a potential bike now . They are a lot of motorcycle for a reasonable amount of money and I want something reliable that I can just drag out of the garage and go . I have seen a few mega cheap ones now I know why they are cheap ! Probably got the same problem as yours . However didn't seem too scary to do and not that expensive to rectify so might be worth a punt . I've got a few old bikes and you usually have to deal with 50 years of bodging by PO s before you can actually fix any problems . Frustrating at times but rewarding when you manage to crack a problem . Happy motorcycling .
Matchless?58 wrote:I do really like the look of the trident and have been considering getting one for a while now . At least I know what to look for when viewing a potential bike now . They are a lot of motorcycle for a reasonable amount of money and I want something reliable that I can just drag out of the garage and go . I have seen a few mega cheap ones now I know why they are cheap ! Probably got the same problem as yours . However didn't seem too scary to do and not that expensive to rectify so might be worth a punt . I've got a few old bikes and you usually have to deal with 50 years of bodging by PO s before you can actually fix any problems . Frustrating at times but rewarding when you manage to crack a problem . Happy motorcycling .
Arghh Chris you could have had mine I only sold it a few months back, sadly she was sat in the garage, taxed, insured and MOT'd but I hardly got to ride it and found last year I had only done MOT mileage so I put it up for sale and had many calls, she sold no problem.
They are a very good motorcycle but very heavy, and compared to many modern bikes they would not live with many quicker smaller CC machines but have lots of low down grunt, are generally 'bullet proof' and all I can say is that I liked the two that I owned, they get the thumbs up from me.
Christer good luck with your bike post a couple of photos they are always appreciated and glad I could help somebody else.
- Real name: Chris
Matchless?58 wrote:Sods law they call that !!!!
Never mind daft thing is it had crossed my mind to put it on here, I don't know why I didn't
