Right guys I've noticed one or two models now with custom brass handrails fitted and I have to say it looks so much better! So now I'm in a position where I've got a couple of spare diggers that I can "experiment" with! So I just need to know what I need and the best places to get them from I.e what soldering iron and wire to use + tips on soldering and bending
Cheers dan
Brass handrails
- Real name: Martin Williams
- Has thanked: 9 times
- Been thanked: 43 times
Re: Brass handrails
Hi Dan,
I have done it on many of my models now and I have learned a lot.
for 1:50 scale models I have found 1:32 brass rods look the best. I started off using soldering wire and flux but unless you are a ninja solderer its hard and messy work so I went with a flux/solder paste.
Have a look at my post.
Soldering with solder paste
It comes in a tiny pot, you dab some paste on the joints and then just touch it with the iron and it's done!
here are a few pics of the things I have done using the paste.
Replaced the big plastic Joal rails on my WA900 from this-
To this-
I changed the rails on my PC1100 from this-
To this.
The PC1100 was done with the solder wire and was a really fiddly job and not as tidy as the stuff I have done with the paste. You will need some really small fine metail files too.
I bend the brass in either a small modeling vice or a good set of pliers. As for a soldering iron, I have a cheap maplin 30w one that does ok.
Hope some of that helps?
To this-
To this.
Topic author - Posts: 117
- Real name: Dan buttress
Re: Brass handrails
That's brilliant, can you recommend any shops that I could get the wire/paste/glue from, it's the pc1100 that I'm goin to be experimenting with as I've got 4 of the excavator versions now
Re: Brass handrails
Go onto ebay and type this item no into the search bar 270532380756 That will get you the paste, only prob is is trebbled in price since I last bought it, £15 now.
The brass rod you should be able to get in any good model shop or here for example -
http://www.modelhobbies.co.uk/shop/modelling-materials-metal-sections-c-64_157.html
This is what I did with my PC1100 face shovel just to give you some ideas
My custom JOAL Komatsu PC1100
Re: Brass handrails
Fantastic job with the komatsu that's exactly what I'm trying to achieve, if I get any problems or any questions i'l give you a shout if that's ok.
Turns out that model shop is only about 20mins down the road from me so that's a bonus!!!
Once I've figured out the handrail side of things I'm goin to look into adding hydrolic hose detail but i'l stick to one step at a time!!!
Re: Brass handrails
Feel free to give me a shout, I will try and help you out!
For hydraulic hoses get some 99p headphones from ASDA, thats what I used for the hoses on my Komatsu.
