Model Rams
Discuss earthmoving models here
Dah
Real name: Dave
Has thanked: 18 times
Been thanked: 67 times
Model Rams
Post #1 by Dah » Mon Jun 20, 2016 2:39 pm
Has anyone ever found a good solution to model rams that are too loose?
Thanks,
Dave
ron54
Real name: phill
Has thanked: 15 times
Been thanked: 1 time
Re: Model Rams
Post #2 by ron54 » Mon Jun 20, 2016 11:09 pm
If they are the usual moulded type with shiny metal rod insert try this; Disconnect the insert and pull it right out.. degrease it and holding vertically by its non ram end, dip it into a tin of GLOSS varnish.
Still holding it upright allow the excess to run off the end the allow it to dry overnight whilst keeping it in the vertical position (in a bulldog clip or similar).
Repeat if another layer is required...If you muck it up a wipe over with thinners will clear it all. The main thing is to let the varnish dry properly
otherwise it will "grab" the plastic tube. Hope this helps some..
Dah
Real name: Dave
Re: Model Rams
Post #3 by Dah » Tue Jun 21, 2016 9:42 am
Great idea - thanks very much.
topkit
Real name: David
Has thanked: 38 times
Been thanked: 157 times
Re: Model Rams
Post #4 by topkit » Tue Jun 21, 2016 11:17 pm
Give the outer plastic ram a squeeze with a pair of long nose pliers, just be careful that you don't split the plastic.
