winget 4s dumper
Discuss dumpers here
Has thanked: 1873 times
Been thanked: 1692 times
Re: winget 4s dumper
Post #11 by Jeremy Rowland » Thu Nov 21, 2013 7:15 pm
mechman wrote:tried cold start lever etc cant tow it as yet because of wrecked track rod will try when track rod situ remedied.
How big was the guy on youtube (just a thought)
According to what it says at the end of the video he is only 16! Now can I ask when you use the de-compressor levers on your dumper does the engine spin over easily or not? Because if the answer is not then I suspect that your dumper engine may have other issues?
mechman
Real name: norman orrick
Has thanked: 144 times
Been thanked: 132 times
Post #12 by mechman » Fri Nov 22, 2013 12:55 am
hi jeremy
the engine spins perfectly untill decompress lever is dropped
Just found there are 2 settings for spill timeing for different rev ranges will have to check it
norm
Post #13 by Jeremy Rowland » Fri Nov 22, 2013 7:44 am
mechman wrote:hi jeremy
norm
Norman it could still be your technique? Watching the video again the lad who starts that particular engine does crank it quite quickly before dropping the de-compressor, unfortunately I am no expert on these engines although I do know that it was possible to start larger engines such as old Gardner engines using the de-compressors.
mechman
Post #14 by mechman » Fri Nov 22, 2013 9:56 am
Hi jeremy
just discovered there are 2 settings for spill timing for different rev ranges will have to check them
norm :dizzy:
mechman
Post #15 by mechman » Fri Nov 22, 2013 7:04 pm
Hi all
Re my first inquiry about track rod ends.
Well ive got a complete track rod off an LDV van the tapered joints are closest ive found so far so its getting cut and shut & fitted so i can move the vehicle ;)
mechman
Post #16 by mechman » Sat Nov 23, 2013 8:08 pm
Hi one and all
Got the engine started today but only run on 1 cylinder fuel is up to the injector so reckon the injector needs a coat of looking at.
good points seem to be - no nasty noises or smoke.
hey ho here we go getting there
Norm
weldit
Real name: Ian Whitaker
Post #17 by weldit » Sat Nov 23, 2013 8:50 pm
mechman wrote:Hi one and all
Norm
Norm, whip the "dead" injector out and see if it's the type which can be dismantled fairly easily. I just wish I could remember what's in there! Been there, done that and forgot all about it.....
It's my age, you know.
Ian
mechman
Post #18 by mechman » Sat Nov 23, 2013 9:14 pm
Thanks ian
Do i need a whitworth whip or what
Norm
weldit
Post #19 by weldit » Sat Nov 23, 2013 11:56 pm
I don't think there is a standard for whips as there are so many potential variables.
As I see it, any whip will do. :D
Ian
mechman
Post #20 by mechman » Wed Nov 27, 2013 10:43 pm
Hi all
has anyone any ideas on how to remove the injectors on this PH2 engine without using semtex they seem to be as one with the heads
norm
Return to “Dumpers”
