Hi guys, this seemed the most relevant thread to ask a question on my Thwaites Nimbus.
I also have a bit of clutch slip, have tightened up & improved a little, I think i need to loose some play in the linkage to improve further too. However whilst playing I wondered what this thing is as it's shot to bits. Is it the release bearing? It's rusted out inside & loose. Also is the fork that presses on it mean to have some kind of friction material on it? Any links to replacements if required appreciated along with any fitting tips please...
Original URL: http://content.screencast.com/users/peteholliday/folders/Jing/media/a8a91cbf-12fb-4fcf-ba01-1960ec2f2034/2017-01-04_0746.png
Thanks Pete.
thwaites brake drum clutch
- Real name: Pete
Re: thwaites brake drum clutch
Pete; while I have not seen a clutch like this before I'd guess that it sounds like its pretty shot? Can you get the bits okay? If not there must be a standard bearing that will fit the release bearing and the friction plate can be relined with new friction material.
- Been thanked: 684 times
That is your clutch release bearing. The mech from the pedal is stationary and the whole clutch drum is spinning with the engine running. so the bearing is critical for smooth clutch operation. New bearing from somewhere I guess and make sure the clutch T lever is not rubbing on the new bearing continuously. I would doubt the clutch T or fork would have hardened material, just the bearing face.
- Real name: Pete
essexpete wrote:That is your clutch release bearing. The mech from the pedal is stationary and the whole clutch drum is spinning with the engine running. so the bearing is critical for smooth clutch operation. New bearing from somewhere I guess and make sure the clutch T lever is not rubbing on the new bearing continuously. I would doubt the clutch T or fork would have hardened material, just the bearing face.
Thanks essexpete. Cool at least I was down the right lines... I found this http://www.lsengineers.co.uk/clutch-release-bearing-for-thwaites-benford-winget-dumpers.html but it doesn't look quite the same & no idea how to get the old one off / fit new one.
Can't remember it must be over 35 years ago I messed about with our old Nimbus. (learnt to drive on it) The release bearing you have found is for (I would think) the later conventional type clutch. I have a feeling the old Nimbus release bearing was just pressed on to the shaft. Actuation would not pull it off if you see what I mean. Put clutch release bearing into an ebay search and see what you can find. You need to remove the old one and measure the fitting size. I expect the bearing was used somewhere else in the motor industry in that era.
- Real name: Pete
Thanks. I'll try get it off and go from there.
I learnt to drive on one too but only 28 years ago haha. That's why I nostalgicly bought this model
Cheekymonkey wrote:Thanks. I'll try get it off and go from there.
35 years ago that I last tinkered but over 40 years for first drive. Oh bloody 'ell
essexpete wrote:Cheekymonkey wrote:Thanks. I'll try get it off and go from there.
Good memories though and that's all that matters!
- Real name: Wayne
Guys, I know this is an old thread that keeps getting resurrected - but.
I have to take the clutch drum off the gearbox to change the seal and bearing.
Do i take the nuts off the studs that surround the clutch return spring? if so.. I wi;l have to split the nuts, because the studs are spinning
If someone DOES have a service manual for the clutch and the CM Newage gearbox (Thwaites Orion) - I would be grateful.
Thanks Guys.
Thanks Guys.
no, just the hinge bolt on the release fork and it all slides off, watch for the key.
