thwaites brake drum clutch
Discuss dumpers here
poirot
Real name: chris allen
Post #1 by poirot » Sat Oct 12, 2013 6:07 pm
Hi all, new bloke here with a nice little thwaites dumper that I recently discovered has a brake drum for a clutch (which after I spent some time thinking about it is quite a nifty idea) Owever, it is currently a slipping clutch, not too badly yet, will still drive just cant manage an incline with a load in the skip. I've spent a while scrolling through the various posts but cant find any clear idea as to how to go about adjusting it or stripping it down for a more in depth repair; the square adjuster nut seems to be seized so the strip down may be necessary anyway; I'd just like a few pointers so I don't get that big spring and the attached metal smacking me in the nose ( i do know enough not to put my nose in front of it) Is there any scope to just adjust the shoes up and get a few more months out of it, or do I need the whole strip down; any assistance gratefully received
Poirot.
Has thanked: 463 times
Been thanked: 287 times
Re: thwaites brake drum clutch
Post #2 by essexpete » Sun Oct 13, 2013 11:46 am
The little Thwaites dumper (30+ yrs ago) is about the only gearbox that I have stripped completely but oddly never had to replace anything in the clutch drum. Sounds like you will have to strip it to free it up. IIRR you can pull it off as a complete unit and work on it on the bench. If the shoes are not worn but glazed you might get away with a clean/fine emery. Be careful with the dust as it might well contain asbestos.
Tillywolves
Real name: Richard
Has thanked: 11 times
Been thanked: 19 times
Post #3 by Tillywolves » Sun Mar 30, 2014 11:14 am
Is there a service guide to this, as I need to do a strip down as well. Are the internal springs, and retaining clips, holding the shoes in place, also off the shelf Triumph Herald parts.
Tillywolves
Real name: Richard
Post #4 by Tillywolves » Sun Mar 30, 2014 8:33 pm
Is your drum clutch like mine ?
Colinb
Real name: Colin brett
Post #5 by Colinb » Sun Feb 28, 2016 5:16 pm
I happened upon this schematic recently hope it's of use to somebody
SiH
Real name: Simon
Has thanked: 88 times
Been thanked: 5 times
Flag: France
Post #6 by SiH » Fri Mar 04, 2016 2:31 pm
My thwaites dumper clutch is slipping in high gears too. It's a 4wd,artic steer,mk3, 2 tonnes apparently,( there's a pic of it on my post 'What is this?'). The clutch drum looks a lot deeper/wider on mine than the one above. Mines been stood out for over 5 or more years,so hopefully it might be rust covering that's causing it to slip. Anyone done one?
Has thanked: 1165 times
Been thanked: 979 times
Post #7 by Jeremy Rowland » Fri Mar 04, 2016 3:07 pm
SiH wrote:My thwaites dumper clutch is slipping in high gears too. It's a 4wd,artic steer,mk3, 2 tonnes apparently,( there's a pic of it on my post 'What is this?'). The clutch drum looks a lot deeper/wider on mine than the one above. Mines been stood out for over 5 or more years,so hopefully it might be rust covering that's causing it to slip. Anyone done one?
Simon rust would not cause a clutch to slip if you look at the top photo above the square for the 'notes' I have typed 'this is the adjuster' and it is very similar to a car brake adjuster(probably square); you screw the adjuster in until the drum cannot be freely turned then back it off slowly until the drum just rotates freely, the clutch should then be adjusted correctly.
The adjusters do rust and seize so it may take some freeing off; try and adjust it and see how you get on, trial and error is probably the best way, if after adjustment the clutch slips them it may well need new linings in which case you will need to strip it and get the brake/clutch shoes repaired, there are plenty of companies around who can do this for you.
SiH
Real name: Simon
Flag: France
Post #8 by SiH » Sat Mar 05, 2016 10:08 am
Thanks for that Jeremy- I haven't even got underneath to have a look at it yet in the few weeks since I bought it. Good to hear it sounds so simple though,even if I do need to strip it all in the end. I do like these old machines for there practicality to work on. :rockon:
Has thanked: 992 times
Been thanked: 893 times
Post #9 by FOWLER MAN » Sun Mar 06, 2016 8:43 pm
Hi Simon,
When you adjust the clutch get someone to sit on the dumper and depress the pedal to fully release the clutch then hold it down.
Tighten the square on the adjuster all the way till it's tight, slack it back about two flats, (enough to free the drum), then release the pedal and hopefully all should be well.
SiH
Real name: Simon
Flag: France
Post #10 by SiH » Mon Mar 07, 2016 10:06 pm
Cheers Fred! That's brilliant-sounds just the job. I'll get on and do that soon. :)
Return to “Dumpers”
