Hi, newby here, i have a Thwaites 2 tonne with a 3 cyl lister diesel electric start, frony axle handbrake with the two levers one on ech side of the prop shaft fitting and 16 inch rim tyres (wouldn't it help if the plated the dumpers). The front axle is tight and it seems the brakes are fastened on, i have stripped off tyhe handbrake and diff cover to have a look but cannot see anything and now i cannot get the cover back on as it seems the hand brake levers are not entering the correct position.
Any help welcome especially if a diagram was available showing exploded view of front axle so i coulsd tackle the job with some knowledge rather than blind as it is at present
Front Axle iisues
Re: Front Axle iisues
Sounds like you might have a 3ton if it is a 3cyl (unless they fitted 3s later on) Our old 2t has hyd front brakes only with the handbrake acting on the same brakes with levers as you describe. The main fault for brakes binding has actually been the handbrake cable not free.
