Can anybody Identify the following Benford Dumper
Benford Dumper
Model - ?
Year - ?
Capacity - ?
2-Wheel Drive - Rigid Frame
Manually Operated Skip
Seat is on the Right
Clutch & Drive - By 3" Wide Flat Belt (Green / Nylon) with Spring Loaded Idler Gear
Gears - Forward & Reverse only
Single Cylinder Petters Motor (AVA1)
Air Cooled
Hand Start
Motor Number - 2693 S (? - Does not seem to fit any Number Sequence)
Injector Pump (Cannot Read References)
Injector - Angled into the head (Not Horizontal) with Bleed back to the Fuel Tank
Drive Wheels - 5-Stud (6" x 16" - Implement Tyres)
Steering Wheels - 3-Stud (5.5" x 16" 3-Rib - Implement Tyres)
Petter Motor
The Petter Engine I/D Plate has been shotblasted so it is a little difficult to read but -
this is what it says
Type AVA1 STD
No. 2693.S STD
BHP 5.5 1650
Many thanks for your help
Benford Identification
- Real name: martyn henley
- Has thanked: 38 times
- Been thanked: 50 times
Re: Benford Identification
Hello Mike, welcome to CMN
To help to identify your dumper more precisely would it be possible to upload some photos of dumper ...
Thanks Pete,
As soon as I get it off its Axle Stands I will pose it for a photo
I cleaned out the Sump and Suction Filter on the Petter at the weekend
I had to get my hand inside the case and scoop out the sludge - much too thick to run out of the drain hole
Cannot make up my mind whether that was its First service in 50 years or actually its First Service - at least there is some oil going up to the Rockers now
Gearbox and Diff Unit next
Mike
Mike
Users browsing this forum: No registered users and 63 guests
