Thwaites Alldrive info required please
Posted: Sat Nov 21, 2009 11:12 pm
Hi, newbie to this forum here. I'm looking for a replacement diff unit for an early Thwaites Alldrive 2tonner. Its a salisbury axle unit and appears to be scarce as hens teeth! The pinion was an 8 tooth before the metalmunchers ate them all, and the crownwheel is a 51 tooth. Any info on these would be appreciated - I know several of the dumper makers used the same engines/axle/gearboxes etc for example, so info on swapable options would be good, as would s/h parts sources. Info on repair manual sources is also welcome.
Thanks folks - and congrats on an interesting forum
